Drivetrain Clutch: Valeo smf kit vs OEM dmf kit
Old Dec 9, 2010 | 06:14 PM
SuprCoop's Avatar
SuprCoop
Ok, I've done the reading on clutches, decided that a relatively stock setup will work for me, my planned upgrades and how I drive my car.
What I haven't found are many reviews from people who have been running the Valeo kit and how it feels/compares/wears compared to the stock setup.
I don't think I'll be doing this myself, I don't have the right tools/space to do this kind of job. But I'd also like a detailed (if possible?) list of things to replace while it's all out of the car. C-arm bushings? Any seals? Hoses? I saw mention of trans forks?
Thanks in advance
Old Dec 9, 2010 | 09:56 PM
FlzRider's Avatar
FlzRider
https://www.northamericanmotoring.co...lutch-kit.html
Old Dec 10, 2010 | 09:11 AM
Jazzop's Avatar
Jazzop
Lower motor/gearbox mount-- replace or install polyurethane insert (as needed/desired)
Slave cylinder-- replace. It's cheap in both quality and price, so go ahead.
Control arm bushings-- At least inspect them. The clutch job gets you about halfway there to replace those bushings, so the decision to replace them is kind of a judgment call.
Power steering pump/hose-- these are failure-prone, so inspect and if there's any leakage at all...
That's all that comes to mind right now. I'm sure there's more. Since you are the kind of guy to stick with a stock flywheel/clutch combo, I won't bother you with all the mods and upgrades you could do while you're in there.
Old Dec 10, 2010 | 11:25 AM
SuprCoop's Avatar
SuprCoop
FLZRider, saw that link, but looking for more than one or two opinions if possible. Hoping that others have that setup.
Jazzop, already have the lower/gearbox mount inserts.
The rest, thank you. Thinking of upgrading the control arm bushings with poly ones. I know one of the ps hoses was leaking at the canister, so I'll consider that too.
I'm sticking with a stock'ish combo since it's my daily driver, and the side effects of a more race'ish setup don't sound too appealing for a DD. But...would you mind throwing the mods and upgrades that can be done at me? I'm ALWAYS up for a good upgrade to my car =)
blackie
Oct 2, 2015 07:41 PM
bneer
Aug 20, 2015 05:38 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 16, 2015 01:15 PM
