Drivetrain Higher RPMs on MCS engine
Old Dec 30, 2003 | 05:19 PM
Farmer's Avatar
Farmer
Water pump cavitation, SC rotational max, ECU rejiggering and whatnot aside, what in the core MCS engine block precludes higher RPMs? 10k, say, for a number. Or am I way off base in even thinking about this?
Old Dec 30, 2003 | 05:43 PM
MartyR's Avatar
MartyR
definitely s/c rpm (allegedly reliable up to ~17 or 18k rpm); regardless, at some point you sacrifice charge cooling capacity due to the heat increase generated by increased s/c rpm
valve train, my guess (esp. valve springs)
cam, again speculation
lack of a flux capacitor (which...is...what makes time travel possible)
M
Old Dec 30, 2003 | 05:49 PM
ZAMIRZ's Avatar
ZAMIRZ
you'd definately need titanium valve springs and retainers, probably would want any excess metal from castings taken off the internals, have the crank knife-edged, get lightweight sodium-filled valves (does the MINI S come with these already???).......You'd probably want to ditch the eaton S/C setup and either go with a centrifigul blower or exhaust-driven turbo setup.
Old Dec 30, 2003 | 05:51 PM
timj1231's Avatar
timj1231
I believe a lot of what will limit the engine will be the oiling system. Only designed for around say 8,000 rpm. No Oil No More go fast ! The internas probably could be balanced for ? 12,000 but again I think the oiling is the limiting factor.
I can run probably 12,000-14,000 rpm on my old school Vespa 2 stroke scooters but the engines are balanced and blue printed...
Old Dec 30, 2003 | 06:17 PM
Farmer's Avatar
Farmer
Dang, answered my ownself, at least on one point: the lifters would need to be solid vs. hydraulic. Else, engine gurus, at what RPM is hydraulic still OK and why?
rob&JCW
Feb 13, 2023 07:03 PM
David.R53
Sep 1, 2015 06:49 PM
makg
Aug 21, 2015 02:49 AM
DWooderson
Aug 20, 2015 04:31 AM
stellaherself
Aug 14, 2015 05:28 AM
