Drivetrain P0171 (Lean) and 20 mpg?
Old Nov 26, 2010 | 08:43 PM
speedracer1600's Avatar
speedracer1600
Well I have a dilemma now on my hands. I am getting 20mpg and the p0171 code comes up intermittently... What are your guys experience on this?
Mods are Alta CAI, 15%, DT BPV, VGS, IK22 Plugs
and the tail pipes are clean!
Old Nov 27, 2010 | 06:42 AM
ZippyNH's Avatar
ZippyNH
Look around for a vacume leak....(I haven't looked up the code though).
Poor mpg/lean codes usually go hand in hand...
And the clean tailpipe let's you know it is likely a real issue...mini's usually run rich.
Old Nov 27, 2010 | 07:29 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Make sure the VGS isn't leaking, or put it back to stock.
Old Nov 27, 2010 | 11:46 AM
ggcadc's Avatar
ggcadc
what temps are you driving in? the colder it gets, the leaner youll run. also make sure your running quality fuel. check to make sure your fuel rail is getting full pressure (51psi), im sure theres a how to posted somewhere
Old Nov 28, 2010 | 02:33 PM
speedracer1600
Well Im here in the Chula Vista area of San Diego. Im not so sure it is a fuel delivery problem as the gas mileage is horrible well 20 mpg. If it was truly just running lean and the mileage was in the 30s then i would say for sure its a delivery problem. does that make sense? Thank you for the suggestions!!!
Old Nov 28, 2010 | 02:42 PM
ZippyNH's Avatar
ZippyNH
The color of the tail pipes let's you know it is lean...matches up well with the codes...
Remember, a mini will make a bit of black soot on the pipes...
None is what most cars make...(mini's run rich from the factory)
White/gray is very lean...
Unmetered air will drop mpg..a vac leak...or an intake, etc, due to loss of efficiency.
There are a few ways to check for leaks...listen for hissing, using an unlit propane tourch...(carefully) and letting the gas get sucked in will cause an rpm change....
Old Nov 28, 2010 | 04:35 PM
speedracer1600
Well, I just un did the vgs mod and the car still runs the same I did find that that one of the IC boots was slightly pinched, I fixed that and wiped everything down really good, went to the gas station filled it up and reset the computer. I will wait to see what kind of mileage I get. I did check for vacuum leaks with some brake cleaner but came up empty.
Old Nov 29, 2010 | 08:33 AM
ggcadc's Avatar
ggcadc
i wish my tailpipes were clean, they're always aweful. anyway, check to make sure your fuel pressure is at 51 PSI, if you pull the intercooler the rail is right there with threads to attach something like this: fuel pressure tester
if it isnt an intake or vaccuum leak, that would be my next best guess
Old Nov 29, 2010 | 12:06 PM
speedracer1600
I have a tester but the rail is too close to the air horn. I need to get a 90* adapter of some sort in order to make it work. I am wondering if the transfer hose from the fuel pump to the basin fell off I highly doubt it but my next task is to check for that. I want to run some miles on it and see where the fuel milage goes to see if i found it. The next step if not is going to be an appointment and a local shop with a smoke machine to help find the Vacuum leak.
I wonder if there is a FPG that will attach to the end of the rail that I can leave permanently in the car.
Old Nov 29, 2010 | 01:45 PM
ggcadc's Avatar
ggcadc
marshalls hardware on miramar rd will for sure have a 90* adapter to get you the clearance you need. that place is amazing
misterbl
Sep 16, 2015 11:22 AM
HaveATank
Sep 16, 2015 08:32 AM
BadgeFTW
Sep 14, 2015 03:49 PM
kjd186
Sep 9, 2015 10:02 AM
