Drivetrain Pulley and Intake questions?
Old Nov 27, 2010 | 08:33 PM
  #26
R53Warrior's Avatar
R53Warrior
Zero problems with my 17% Alta pulley. They rented/borrowed me their puller with everything to use it. Idk if they still do it but mine worked fine. No regrets at all.
Old Nov 28, 2010 | 06:29 AM
  #27
ZippyNH's Avatar
ZippyNH
Just be sure to use a tourque wrench to put the pulley on, and a dab of lock-tite...it will be fine. Most folks did prefer the older Alta pulleys collet style fastening method (still used on virtually all other pulleys), but the one you got should serve you well...just get/borrow a puller.
Old Nov 28, 2010 | 07:08 AM
  #28
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Yep it will work fine for a D2D street car, as long as you arent an overly agressive driver. There are a lot of the V2 pullies out there, and I have only heard of a few problems off the track.
Old Nov 28, 2010 | 07:35 AM
  #29
Supertuner12010's Avatar
Supertuner12010
Thats te comments that worry me. Could uyou tell me what problems happened off track? As well as on track.
My driving can get agressive from time to time. And car will see track time about once a month.
Old Nov 28, 2010 | 07:54 AM
  #30
ZippyNH's Avatar
ZippyNH
Simply put the metal expands and contracts at different rates...so the effect is like tightening/loosening the bolts a bit...as long as you use a tourqe wrench and a bit of locktite, you should avoid this issue.
The advantage of the Alta v2 mounting method is it is a bit more tolerant to mounting on a SC ith prior dammage...like from a pulley that had previously slipped...or so I have heard. Installed correctly, no pulley should slip, especially a stainless one. Alta's pulley is aluminum, and they switched mounting methods...I don't think they developed a new version cause they felt like it...there is usually a reason....
Old Nov 28, 2010 | 08:32 AM
  #31
Supertuner12010
Why does everyone say there pulley is aluminum? It is still a 2 piece design, the piece that fits over the supercharger shaft is stainless stell. The piece that bolts to that, is aluminum.
Old Nov 28, 2010 | 08:35 AM
  #32
DICKS GARAGE R53
"I don't think they developed a new version cause they felt like it...there is usually a reason...." ZippyNH
Reason being R56 in this case.^^^^
Pretty much everyone slowed way down developing new parts for the R53 when the 56 came out, and ALTA was one of the first to jump ship.
Personaly I have seen a few bolts back out of aluminum pullies, and saw one that was totaly seised in place and the dealer couldnt even get it off.
Old Nov 28, 2010 | 08:42 AM
  #33
DICKS GARAGE R53
It is still bolting a pice of aluminum to a pice of steel, the temprature fluctuations between the 2 pices stretch the little bolts holding them togeather and they come loose.
Old Nov 28, 2010 | 11:15 AM
  #34
TYHOGG's Avatar
TYHOGG
The vibration causes more bolt movement than the temperature change. considering the entire motor is made of aluminum, there is no problem with the pulley being made of the same material. If anything it has less rotating mass witch takes less energy to spin it. I've been running a alta v2 15% on the cooper for over 30k miles and ZERO problems.
The linear thermal expansion of aluminum from roughly 70* to 572* is only .00013"'s
and stainless steel is .000094"s, I don't think that .000036 of an inch is going to make any marginal difference.
Old Nov 29, 2010 | 08:06 AM
  #35
rickyr53's Avatar
rickyr53
lol those last numbers were crazy. i ordered the pulley package also and the intake system....hope everything turns out well. Then intake will be installed by me but the pulley by a shop.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
David.R53
Sep 1, 2015 06:49 PM
maniacalmorgan
Aug 19, 2015 08:44 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
