Drivetrain 15% or 17% Reduction
Old Oct 13, 2010 | 09:40 AM
tutono's Avatar
tutono
I have been told that the 17% reduction will cause pining if I do not get the larger fuel injectors. Has anyone experienced this? I have also been told that the 17% will be more likely to burn out the supercharger if I don't control the temps and that the ECu will dump more fuel to try to bring down the temps making the car sluggish. I'd really like to hear results from those who are running a 17% and for how long it has been in use.
Old Oct 13, 2010 | 08:26 PM
WP4LDU's Avatar
WP4LDU
Old Oct 14, 2010 | 05:18 AM
tutono's Avatar
tutono
Is your an automatic? How did the MiniPowerProg work for you? WHat is a Henry-Bypass Valve? Have you experienced any problem at all since installing the 17%?
Old Oct 14, 2010 | 05:34 AM
Achilless's Avatar
Achilless
Tutono, there is a wonderful search tool(top right on page) that would answer all these threads ur starting and asking questions about. Just letting you know if you didn't, these questions can all be answered 100 times if you search.
Old Oct 14, 2010 | 08:51 AM
WP4LDU's Avatar
WP4LDU
Tutono,
I upgraded from 15% to 17% and very happy that I did. I was stationed in Germany and I have had no problems with pinging until I got to WA. I fixed the problem using chevrom and adding octane booster to the fuel tank. I recomend the 17% pulley because with the 15% you will not feel too much difference from stock. The minipowerprog it is an Italian program that comes with the obd cable and cd to connect to your laptop. You upload your mini program to their online server and they will send you the modified file in 24 hours.
Henry
Old Oct 14, 2010 | 09:46 AM
ZippyNH's Avatar
ZippyNH
17% is great for locations that have 93 octane, and IMO cooler temps...
On a hot day the the 15% will be faster, but the rest of the year the 17% IMO is more fun as a street car....
IMO if you spend lots of times at higher rpm's, get the 15%...same for autox and track folks...but the 17% is great for the daildriver with moderate rpm's. I ran a 17 untuned with stock injectors....it will run a bit lean at high rpm's...but I since you spend limited time there, should be ok.
I later got jcw 380's later still a custom Dino tune...
Do a search...there is a ton of info here on this subject!!
bahman
Feb 14, 2016 10:29 AM
WhinyR53
Sep 30, 2015 07:36 AM
bahman
Sep 26, 2015 07:38 PM
HaveATank
Sep 16, 2015 08:32 AM
Mb460
Sep 14, 2015 05:50 AM
