Drivetrain The Official ALTA AccessPORT Thread
Old Sep 14, 2010 | 11:46 AM
  #426
dj.papazian's Avatar
dj.papazian
so when i recieve this tool and proceed to flash my car, is it a MUST to hook my car up to a battery or is it not really necessary?
Old Sep 14, 2010 | 12:03 PM
  #427
mellanor's Avatar
mellanor
It occurs to me that we have an excellent opportunity here to address a question that many have expressed interest in - namely, what kind of performance increase different CAI's provide. If I understand this new tool correctly, it's datalogging feature may give us a window of understanding into how different CAI's perform under actual driving conditions. The problem that has plagued us previously is that any performance gains registered with a dyno are, well, pretty artificial.
So, my question to the Alta guys (given that I personally haven't seen how this tools datalogging feature works): Is it now possible to use this tool to see real world performance changes from upgrades such as CAI's?
Old Sep 14, 2010 | 01:48 PM
  #428
M3irish's Avatar
M3irish
*IF* your battery is in good shape, you *should* be ok.
Old Sep 14, 2010 | 01:50 PM
  #429
jkool44's Avatar
jkool44
You shouldn't have any issue with a good battery. jeff got it all done on my car in the Alta parking lot. Longest part was downloading vehicle information before he loaded the map onto the car. Only takes a few minutes.
Old Sep 14, 2010 | 02:43 PM
  #430
ALTA_Chris's Avatar
ALTA_Chris
It's not 100% necessary, as long as you have been driving the car recently, and you shut off your headlights, radio, etc it should be fine. A battery charger will guarantee that you won't have a problem with the battery dieing.
The datalogging feature will let you look into how the car is reacting to the CAI. It will also let you be able to measure AFR. We are coming out with an update early next week though that will be able to measure horsepower, 0-60 and 1/4 times!
Also there is a new update that came out for the ALTA AccessPORT today! To get the update, run the AP updater.
Old Sep 14, 2010 | 03:39 PM
  #431
scott48's Avatar
scott48
I'm looking forward to that...I'll post my impressions later this week.
Originally Posted by MotorMouth
Judging from the fact that you have a TBE, FMIC, CAI, etc.. You'll be stage 3 and hitting 23 lbs boost.. It's gonna be mean when you press the pedal all the way.
Old Sep 14, 2010 | 03:56 PM
  #432
BamaCooperS's Avatar
BamaCooperS
I've updated successfuly but now I'm not sure what to do now. Do I need to reflash my ECU? Exactly what impact does the AccessPORT updates have?
Thanks.
Old Sep 14, 2010 | 04:04 PM
  #433
skippydog's Avatar
skippydog
A change log would be cool for us geekier folks .
Old Sep 14, 2010 | 04:08 PM
  #434
ALTA_Chris's Avatar
ALTA_Chris
Thanks.
There's nothing else you need to do, we didn't make an update on the maps, but we updated the AccessPORT firmware so the AccessPORT will now work on more ECUs.
Updates can change many things, from adding new features to the AccessPORT, making it work on more cars, or eventually, updating maps.
Old Sep 14, 2010 | 04:19 PM
  #435
skippydog's Avatar
skippydog
Old Sep 14, 2010 | 04:32 PM
  #436
BamaCooperS
Great! Thanks.
Old Sep 14, 2010 | 05:04 PM
  #437
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
Originally Posted by ThumperMCS
23lbs on an S?
eek.
I do get just under 23 PSI on mine if the over-boost feature kicks in, typically though it tops out at 20 PSI.
Old Sep 14, 2010 | 06:43 PM
  #438
countryboyshane's Avatar
countryboyshane
Yikes that is high. Less and less time to TBO
Old Sep 14, 2010 | 07:46 PM
  #439
SimpsonGI's Avatar
SimpsonGI
If you are talking about the 23 PSI it doesn't get that high often and when it does it doesn't stay there very long. My RMW tune did the same thing. If you have a stage 3 MINI both tunes are set for 20 PSI and in an over-boost situation both will top out just under 23 PSI.
Alta is not pushing the turbo to failure by running too much boost anymore than Jan is.
The Alta tune does do a better job of holding the boost pressure right around 20 PSI though compared to my RMW tune.
Old Sep 14, 2010 | 08:03 PM
  #440
dez's Avatar
dez
Old Sep 14, 2010 | 08:31 PM
  #441
dj.papazian
so i recieved my accessPORT in the mail today...and i just want to say its worth every penny.
the stage 2 tune TPS on my 09 JCW is simply unreal. not only is the car so much faster, the powerband is ridiculously smooth. with TPS included in the tune im running now, with the sport button on, my car is not jerky anymore when u push the throttle. its litterally smooth power from beginning all the way pulling hard till the end.
i didnt have much time to drive with it today (perhaps an hour or so), but its a VERY noticeable feel in power and so far i cant wait to drive it again 2morro. I'll drive more tomorro and keep you guys updated! Big thanks again to Alta for making this all happen!
p.s. no more CEL light on my speedometer EVERYtime i drive (because of my downpipe) makes this a visually appealing mod as well. Well done Alta!
Old Sep 14, 2010 | 10:37 PM
  #442
ThumperMCS's Avatar
ThumperMCS
I haven't heard of many RMW cars running 20+psi...
Most are around 17-18...and yet they make almost the same power as the Cobb cars running 20+psi. Sometimes less can be more
It'll be interesting to see how he tunes them with the AP
Old Sep 15, 2010 | 12:05 AM
  #443
SimpsonGI's Avatar
SimpsonGI
well now you have My RMW tune gets the same peak boost as my Alta tune. I know you are a staunch RMW supporter but you can't compare the tunes if you don't have them both. I do. Alta's tune is currently better IMHO. I am only one of many who have tried both tunes and have indicated the Alta tune provides more power, better drivability, clears CELs from downpipes, and they provide better customer service. Especially in terms of support there is no comparison.
Old Sep 15, 2010 | 05:43 AM
  #444
///Mflossin's Avatar
///Mflossin
Old Sep 15, 2010 | 06:52 AM
  #445
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Thank you all for the support and the continued updates. Lots of good information and feedback here. Tons more to come too!
Thank you again!
Old Sep 15, 2010 | 07:21 AM
  #446
futuremini's Avatar
futuremini
I have both the RMW and the AP. I can't compare them though as the AP is having trouble recognizing my ecu. Jeff is working to figure this out and YES I have the latest firmware updates. The latest updates were loaded on the second AP I was sent which I received on Tuesday. Even with the updates the AP still can't recognize my ecu. The first AP froze up while trying to update the firmware.
I am anxious to make the comparison but don't know how soon or if I will get to do so. Only time will tell.
Old Sep 15, 2010 | 08:18 AM
  #447
ALTA_Chris's Avatar
ALTA_Chris
Futuremini,
Sorry about the updating issue. With the newest update from yesterday afternoon, the freezing during updating has been fixed. A second AccessPORT was sent out before we found out that the freezing during update issue was ironed out, we actually have a way now to unfreeze the AccessPORT. If you run an update right now, the update will be able to complete, and should able to load on your ECU! Jeff also sent you an email, please get back to him or give us a call, thanks!
Old Sep 15, 2010 | 08:21 AM
  #448
futuremini's Avatar
futuremini
Awesome! Thanks Chris! Leave it to me to have some weird issue.....
Old Sep 15, 2010 | 10:11 AM
  #449
redduc's Avatar
redduc
Seriously, you are the test subject for EVERY SINGLE weird problem. I think everyone should send you a dollar.
Old Sep 15, 2010 | 10:57 AM
  #450
futuremini's Avatar
futuremini
...seems like it sometimes redduc!
Good news though. The latest firmware upgrade as of today has fixed the issue I was having with the AP recognizing my ecu. The AP loaded the map to my ecu with no problems and functions correctly. Now for the test drive tonight.
THANKS JEFF AND CHRIS!
