Drivetrain Getting some air?
Old Aug 5, 2010 | 02:47 PM
  #26
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Keep the IC for that price. And get yourself an M7 Ram scoop (or similar, I think there was one on Ebay, but I'm not sure if anyone ever bought and installed one of these.) The Scoop will work with the stock IC if using a good diverter, so that's the best bet to improve intake system performance. I doubt the horizontal flow IC will improve performance, but it's unlikely you'll detect any significant decrease in performance either.
Good luck.
Old Aug 6, 2010 | 08:52 PM
  #27
JumpingJackFlash's Avatar
JumpingJackFlash
Here are some pics of the factory IC with the thermal coating. After taking a test drive to make sure there were no vacuum/boost leaks, I came back and parked. I could actually hold my hand on the IC for about a second before it felt too hot. That tells me the coating is working.
Old Aug 6, 2010 | 09:14 PM
  #28
Achilless's Avatar
Achilless
^ looks good. how long did the whole thing take (sending it to them and getting it back) and that's not a bad price, 1. helps in performance 2. looks great!
Old Aug 6, 2010 | 10:08 PM
  #29
Dr Obnxs's Avatar
Dr Obnxs
Turn around is pretty fast...
on the order of a week, plus or minus.
Matt
Old Aug 6, 2010 | 10:17 PM
  #30
JumpingJackFlash
Yes, about a week. I'm glad I finally got around to doing this.
Old Aug 6, 2010 | 10:24 PM
  #31
Dr Obnxs's Avatar
Dr Obnxs
It's cheap... It works (a bit)
and it's black!
So there you go!
Matt
And they do a really good job of cleaning the IC as part of the process!
Old Aug 8, 2010 | 05:04 PM
  #32
blue agave's Avatar
blue agave
I installed the Alta IC, but haven't been able to test it out due to a power steering pump failure under repair. The IC does not line up perfectly with the air tubes, as did the factory part. The driver's side rubber coupling is slightly stretched out at one side, so it's wider toward the firewall side than at radiator side. However, it does fully cover both of the clamping surfaces. Any opinions of whether this will disturb airflow or o/w affect performance?
Also, the unit is so large it sits over the spark plug boots. I'll have to remove the IC to service the plugs A major pain in the ***.
Old Aug 8, 2010 | 05:53 PM
  #33
Dr Obnxs's Avatar
Dr Obnxs
So do most...
including the GP. Really, at first it's hard to remove/replace the IC, but now for me it doesn't take much time at all.
Matt
Old Aug 8, 2010 | 06:29 PM
  #34
DrPhilGandini
Matt
I've seen a cam changed in 30 minutes, and for me (like DrO) taking the IC out takes less than 10 minutes and is no big deal.
And honestly, how often are you changing spark plugs? Really. The maintenance cycle for the IC is shorter than that of plugs, so it's not big deal.
btw, if you don't modify the mounts for the Alta horizontal IC, you may get dents in the bonnet--some early adopters found this out the hard way.
Old Aug 11, 2010 | 04:52 AM
  #35
ajv915's Avatar
ajv915
Maintenance cycle for the CAC? What maintenance do you have to do to it?
Old Aug 11, 2010 | 10:14 AM
  #36
DrPhilGandini
Maintenance of the Intercooler includes cleaning it, and maybe straightening bent cooling fins. Even with an oil catch can you will find oil in the IC--ranging from a lot to a very little. It reduces the thermal efficiency of the IC so it's good to clean it out.
Old Aug 11, 2010 | 11:06 AM
  #37
ajv915's Avatar
ajv915
yeah about an hour after posting I was thinking that maybe cleaning it would help. The oil catch can is a nifty idea, but really I don't think I am driving it hard enough to need that. Yes I do like the occasional Hoon but nothing severe.
I would hope that the fins say pretty straight, the ones that I see bent the most are the ones that have caught a rather large bug.
Old Aug 11, 2010 | 11:23 AM
  #38
Achilless's Avatar
Achilless
How would you go about re-straightening a fin, simply taking a needle nose and bending it back? I have a couple that are...
Old Aug 13, 2010 | 09:16 AM
  #39
DrPhilGandini
You could use needle nose pliers, or an awl to simply push the fins back into position. It's never going to be perfect, but you can improve the airflow over the damaged, deformed fins.
Old Aug 13, 2010 | 09:44 AM
  #40
blue agave's Avatar
blue agave
We may as well eat the whole enchilada: How does one clean out their IC? Muriatic acid bath or soapy water and a garden hose?
Old Aug 13, 2010 | 01:06 PM
  #41
JumpingJackFlash
Achilless, you can actually buy a special comb that straightens out the fins on the radiator, IC, etc. I don't have one, so I used a small flathead screwdriver.
blue_agave, the company I shipped my IC to cleaned it for me. If you want do do it yourself, buy a can of Gunk engine degreaser and hit the entire engine. Let it soak for a few before rinsing.
Old Aug 13, 2010 | 01:40 PM
  #42
ZlotyR50's Avatar
ZlotyR50
Coat your IC why??
Sorry I must be missing something...How is adding a thermal coating going to help? It should hurt not help. You want the air rushing over the fins/centers to cool the centers and take away the heat from the tubes (intake air is in the tubes). Anything that gets heat out of the tubes more efficiently the better and the cooler the air going to the motor will be. If you coat/insulate the tubes you prevent the heat from getting out. Anything you do to coat the tubes or centers (unless it is heat conductive material on the center) will make the heat transfer worse. The coating will also increase the air pressure drop minutely which actually means on a theoretical level you have less air going through (a much scaled down version of blocking the entrance or the exit).
Old Aug 13, 2010 | 01:58 PM
  #43
JumpingJackFlash
Here's Cradin's explanation: http://www.cradin.com/thermal_dispersant.htm. Another site (scroll down to thermal dispersant): http://www.techlinecoatings.com/introduction.html.
Old Aug 13, 2010 | 02:17 PM
  #44
ZlotyR50's Avatar
ZlotyR50
Thanks JumpingJack...I didn't realize it was some type of dispersant. If it actually works as they claim it makes more sense than my original interpretation of "coating". I would like to test it on a dissipater to see if it really does what they say….
Old Aug 15, 2010 | 10:44 AM
  #45
Dr Obnxs's Avatar
Dr Obnxs
I tested it...
dropped IATs a couple of degrees. No a lot, but it's a real effect.
Matt
sleek55044
Oct 14, 2016 01:52 PM
Mini Hooper
Sep 17, 2015 01:58 PM
Sep 10, 2015 11:55 AM
M7Speed
Sep 3, 2015 07:48 AM
