Drivetrain Boost loss/belt slip
If your running the stock belt you need to replace it. Also make sure the tensioner is in good shape and the bushings on the tensioner shock are in good shape. If you need either let us know.
Stock belt is 1388mm. I have a 1374mm belt to get the proper tension. Inner tension rod should have one hole showing (about 8-10mm shaft length). Worn out belts can get a "glazing" effect on them, which can cause slippage. Replacing the belt is a good place to start.
RobbyD
Jan 29, 2019 01:22 PM
vulkandino
Oct 31, 2015 08:29 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
