Drivetrain Huge Oil leak after pulley and oil catch can install
Old 03-11-2010, 09:55 AM
nelz886's Avatar
nelz886
nelz886 is offline
I'm not sure if this is the right forum for this but here if goes...
I had a 15% reduction pulley and an oil catch can professionally installed about a week ago. (only other mod is an alta CAI) Now, oil is leaking from "everywhere", every gasket, according to my local mechanic. It looks clearly like a oil pressure issue as every gasket failing at once seems a little unlikely. My question is, was there anything I missed prior to/directly after having these mods installed that caused this? I'm really confused as to where this problem is originating from.
Any help would great. Thanks.
edit --
Car: 2004 R53 Mini Cooper
Old 03-11-2010, 10:16 AM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
If the catch can was not done correctly and is blocked the crankcase pressure will build and blow out the seals like you have. I'd check that first.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 03-11-2010, 10:33 AM
newbs49's Avatar
newbs49
newbs49 is offline
Better check the oil catch can. Lines connected wrong or one may be blocked.
Old 03-11-2010, 10:52 AM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
Kink in the OCC line...
that's the only way you could be leaking from everywhere....
This is one of the reasons I'm not a big fan of OCCs on the first gen new Mini....
Matt
Old 03-11-2010, 10:58 AM
911Fan's Avatar
911Fan
911Fan is offline
I doubt the oil just oozed out around the gaskets. They're probably damaged and will have to be replaced, no?
Old 03-11-2010, 11:26 AM
ALTA_JOHNL's Avatar
ALTA_JOHNL
ALTA_JOHNL is offline
As everyone said, if the catch can is installed incorrectly you will build positive pressure in the crank case and blow out the gaskets.
Old 03-11-2010, 11:34 AM
Oxybluecoop's Avatar
Oxybluecoop
Oxybluecoop is offline
Could you post a pic of your OCC setup?
Old 03-11-2010, 05:39 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Rich.Wolfson is offline
One more vote for an "unprofessional" catch can install. Unfortunately although your seals may have been stressed, some are probably still OK. But any gasket that was blown will probably need to be replaced.
Sorry,
Rich
Old 03-24-2010, 05:13 AM
nelz886's Avatar
nelz886
nelz886 is offline
Thanks for all of your responses. The OCC was relocated and triple checked for a correct installation, still leaking. At this point, we've decided to attack the symptoms (i.e. all the gaskets where oil is leaking from). Still really confused as to the underlying cause here, is it possible the OCC itself was DOA?
Thanks again.
Old 03-24-2010, 06:08 AM
newbs49's Avatar
newbs49
newbs49 is offline
What brand OCC did you install. If you can blow in and out of it, the can should be OK. Sure you don't have a pinched line?
Old 03-24-2010, 06:49 AM
nelz886's Avatar
nelz886
nelz886 is offline
Alta OCC. Not sure about the lines, it's still at the shop that did the work getting the gaskets replaced. :(
Old 03-24-2010, 09:47 PM
DrPhilGandini's Avatar
DrPhilGandini
DrPhilGandini is offline
My little dose of LITHIUM
It is well known (but possibly corrected by now) that the installation instructions for the Alta OCC are incorrect. Read the sticky on OCC to discover what has been known about this problem.
That said, the benefits of an OCC are NOT LARGE ENOUGH to suffer what you have. Uninstall the OCC, replace all the gaskets, and clean out the IC every 6 months. You will be safe, and happy.
Old 06-29-2010, 06:43 PM
silver_scoop's Avatar
silver_scoop
silver_scoop is offline
I've had an alta catch can installed on my 03 mcs for about 2 weeks. on my way to work i hear a thud and the dash lights up. I only drove another 2 blocks to the parking lot look under the hood and oil is everywhere on the passanger side of the engine. I really can't see where its coming from but i can't even see it on the dip stick anymore. I can't find the "stickey" on the revised instructions.
TREX
11-02-2019 07:31 PM
squawSkiBum
10-02-2015 09:21 AM
azntaiji
08-13-2015 03:24 PM
M7Speed
08-06-2015 01:48 PM
Quick Reply: Drivetrain Huge Oil leak after pulley and oil catch can install
