Drivetrain Lubing the Supercharger....
Old May 28, 2010 | 01:28 PM
martinb's Avatar
martinb
I was at Mini Mania a couple weeks ago and heard a discussion about lubing/oiling the supercharger. Apparently, there are two fill holes, one at either end of the supercharger, that you can open up and put in some oil. What can anyone tell me about this?
True?
Is it part of a regular scheduled service?
What oil to use?
How much?
How do you get at the plugs?
Are there drain plugs?
Anything else?
Thanks much!
Old May 28, 2010 | 01:35 PM
gear-head's Avatar
gear-head
Yes there are two:
  • One in the front, very tight but possible to get to
  • One in the rear, behind the water pump, only possible to get to by removing the water pump
From what I've seen, the only one that matters is the rear one. So, unless you're going to be back there ... put it out of your mind, like I have.
Old May 28, 2010 | 06:36 PM
plasticknives's Avatar
plasticknives
To do it properly you'll need to pull the supercharger. Not really labor intensive, just time consuming if you haven't done it before.
You'll want to pull the charger, then take off both ends to inspect the gears. Clean it out, reattach both ends with anaerobic sealer, then fill with GM Supercharger Oil. You can pick it up from any Chevy dealer. I filled mine 6oz in the nose, 2oz in the rear.
Old May 29, 2010 | 05:37 PM
MrCooperS's Avatar
MrCooperS
Moderator
plasticknives
did you do this yourself? how long did it take?
Old May 29, 2010 | 08:31 PM
plasticknives
Originally Posted by MrCooperS
plasticknives
It's hard to say since I did it while I was doing my head swap. I would give yourself the afternoon and evening to do it if you never done it before.
Old May 29, 2010 | 10:35 PM
wrh3's Avatar
wrh3
https://wiki.bentleypublishers.com/d...512ED1A4538BFA
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
David.R53
Sep 13, 2015 03:44 PM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 03:01 PM
minipopkart
Aug 13, 2015 05:22 AM
