Drivetrain Transmission with LSD Fluid?
Old May 27, 2010 | 08:43 AM
Luys's Avatar
Luys
Hi Folks,
It is the time to change the transmission oil and I have 06' transmission with OEM LSD. So which oil do you recommend me?
Thanks from now.
Old May 27, 2010 | 01:28 PM
Luys's Avatar
Luys
Motul PA90, Motul 75-140 or Motul 75-90 ??? or others
Old May 27, 2010 | 03:28 PM
miniconcarne's Avatar
miniconcarne
I use Redline MTL, but I don't have an LSD, so never mind....
Old May 27, 2010 | 04:07 PM
MINI33342's Avatar
MINI33342
Use OEM. About the same price and a very good product.
Otherwise Redline MTL is used a lot.
Old May 27, 2010 | 05:31 PM
solberg's Avatar
solberg
Royal Purple Synchromax will work too
Old May 27, 2010 | 07:29 PM
trippyloaf's Avatar
trippyloaf
I have a 2006 MSC w/OEM limited slip diff and changed my transmission fluid about a year ago (45k miles) with Redline MTL. It's worked fine so far. Lots of city driving and about 6 track days. It even seemed to work better than OEM during the winter.
Old May 27, 2010 | 11:45 PM
R53Warrior's Avatar
R53Warrior
OEM LSD isn't clutch driven so any good transmission fluid will work. I have used redline and royal purple (outside of OEM stuff). I had issues with royal purple in my S2000 so I have stuck to Redline. Their shock-proof gear oil is great for higher abuse but the MTL is perfectly fine for daily and light track use. I have it in my trans right now.
Old May 28, 2010 | 11:12 AM
Luys's Avatar
Luys
Actually we have here in Turkey just Motul, Castrol and Mobil 1.
I am looking to which one to take 70W-80, 75W-90 or 75W-140. Most of the people recommend to me 70W-80 (MTL). But here in Turkey, told me that 75W-90 is full synthetic, it will be better than the 70W-80!
I said let share it with you folks.
Anakist
Sep 23, 2015 08:05 PM
vargasgal
Sep 17, 2015 10:02 AM
Rainforest_Elf
Sep 15, 2015 12:11 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
