Drivetrain my oil catch can recommendation
Thats the one I'm gonna buy actually, its an amazing deal.
From: Camano Island, WA, but wish was still Oahu, Hawaii
I have actually bought the home depot one (the big one). Had a guy make an aluminum bracket for it, bought some cool 90 elbows for it and some good fuel hose. Went to install it and noticed it said max temp was 125F. I don't have a clue on how much heat it will actually see out of the PVC, but it also says to avoid synthetic oils, which is what I use so I started looking for something else...
Me and my friends, as well as many NAM members who uses fuel lines as vac lines don't seem to have problems so I'm just gonna stick with my setup.
home depot occ works well, but buying extra supplies like hoses and so on usually runs up the bill to 40-50 bucks (at least for me it was). And I got lazy with draining the damn thing so often
Drew-
post some pictures when you are done
Just curious if you or your friends have watched what happens to those lines when the engine is underload and at higher RPMS; hint, they collapse. Especially once aged and soaked w/ oil. So what good does said line do, if it is pinched off ?
Now, if you are using "fuel injection" line, you might be ok, but that stuff isnt cheap either.
Like I said, a lot of members here uses the similar lines I'm using (goodyear etc) as well as my friends who are notoriously **** about their cars and none reports any problem with the line getting collapsing.
I think there are 2 huge occ thread here that explains routing and different set up ideas and all uses what I'm using so..
However, if you don't feel safe, then get some silicon hoses from 3rd party and use that.
I just use what others use and check periodically for cracks and lines loosening up.
It's cheap and effective, and even if they somehow go wrong, replacement is hardly expensive.
drew-
I am planning on adding a oil catch can and at the same time installing a Detroit Tuned Bypass Valve. Having read over the instructions for replacing the bypass valve, removal of the Intercooler and one the horns needs to be done and at that time I would clean them. My question is, do you have to replace the silicone couplers or can you reuse the originals? Also, what the best way to clean the Intercooler filter?
what do you mean by intercooler filter?
dude, that mesh IS the intercooler.
you talking about the radiator looking thing right?
I posted a few pics on page 1 of this very thread my friend.
Hmm.....I'm not seeing them. I'm at work, so maybe they're being blocked or something. I'll look when I get home
Hey Drew.
Thanks for this post. I really like the velcro fastening - nice and clean without having to drill holes. How is it holding up with the OCC heating up during use? Does the glue/adhesive on the back of the velcro hold?
Thanks!
Dan
Thanks!
Dan
So far, the the OCC is help up just fine. no problem whatsoever.
Drew-
Hoonpv,
I can't see the pics you posted. It says they were removed from photobucket.
Can you re-post or PM?
I was wondering if you used the included bracket at all or did you slap it on entirely with velcro?
Thx.
Thx.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Aug 21, 2015 12:59 PM
M7Speed
Aug 6, 2015 01:48 PM
