Drivetrain Tsudo Exhaust
Old May 26, 2010 | 01:05 PM
  #26
stevecars60's Avatar
stevecars60
Originally Posted by plasticknives
I'll let you know tonight or tomorrow. I've only driven it for about 5 minutes today down the street to the bank. When I got back home burning smoke was coming out of my tips! From what I read it's just assembly oils and whatnot burning off and will go away after a half hour of driving.
That's exactly right. It will take, maybe, an hour to completely away, smell... etc.
Old May 26, 2010 | 02:24 PM
  #27
plasticknives's Avatar
plasticknives
There's some partial throttle droning around 2500-3100rpm, give or take, but other than that it's pretty quiet. It's nothing unbearable. I wasn't able to test it out with the windows up and didn't really want to push it in the heat. Ambient temps were 100f+ today!!
Old May 26, 2010 | 03:29 PM
  #28
JumpingJackFlash's Avatar
JumpingJackFlash
Sounds just like the Invidia setup I have. I would guess they are using the same mufflers. Not sure if you can get a discount for the dent without shipping the damaged goods back.
Now, the tips. That part matters alot because that's the part everyone sees. If they are not properly lined up, I would send it back and ask them to reweld them or send a new kit.
Old May 26, 2010 | 03:34 PM
  #29
plasticknives
I don't think the dent is worth the effort of sending it back. Yea it sucks, but doesn't really affect anything.
As for the tips, it's not a matter of them lining up, its the angle at which they were cut. I doubt a new kit would be any different. My guess is they had someone cut each side separately and assemble the kits later down the line. A little filing or grinding and they should be as straight as ever.
Really we're talking about a sub $300 system here. Any way you look at it, you can't expect it to be perfect. That's why people pay the $700 price tag for other system, they don't want to deal with modifying it at all.
Old May 27, 2010 | 01:06 PM
  #30
plasticknives
So it was either ship it back for a full refund, or get a $50 partial refund. I opted for the $50.
So because of a small ding, my exhaust is now $229
I definitely can't complain!
Old May 27, 2010 | 01:38 PM
  #31
ImportFreak's Avatar
ImportFreak
Awesome, you managed to convince me. I'm going to see about ordering mine sometime next week. The tips issue kind of bothers me, but for the price I think I will over look it. Whats the best way to coat the tips after grinding them to adjust shape? Looking maybe for a medium dark gun-metal look.
Old May 27, 2010 | 01:48 PM
  #32
JumpingJackFlash
If you want to paint the tips, scuff the surfaces with a fine-grit sandpaper. Probably something like 1500 grit or 2000 grit. Since it's a heat surface, I suggest 500-degree engine primer and paint.
Old Jun 9, 2010 | 08:22 AM
  #33
YMINI's Avatar
YMINI
Thanks Plasticknives.
Is the most of the droning coming from the back of the car or from the middle section there the 1st resonator is located?
For the price I think I'll just weld in additional resonator to minimize the droning.
If it's not too much trouble could you tell me how much space there is between the last turn and end of the tips? I have a couple of nice rolled Borla tips about 8.5" long, wonder if they will not stick too far back if I'll replace the original tips.
Old Jun 11, 2010 | 08:28 PM
  #34
plasticknives
The droning definitely comes from the rear end. I'll get those measurements to you sometime soon.
Old Jun 28, 2010 | 02:25 PM
  #35
andyk30's Avatar
andyk30
I purchase this exhaust from ERZperformance I was able to get a 20 dollars off with coupon code "coupon20"
I got this exhaust for 239 shipped
http://www.erzperformance.com/TSUDO_..._p/20-9355.htm
Old Jun 28, 2010 | 02:32 PM
  #36
plasticknives
Good deal!
Old Jun 28, 2010 | 02:41 PM
  #37
andyk30's Avatar
andyk30
Yeah, I email the vendor ask them if they can beat ebay and speedelement price
Old Jun 28, 2010 | 05:32 PM
  #38
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Hey PK,
Been about 3-4 weeks, do you have any further data on the exhaust set up pros or cons ? Any thoughts of running it with out the resonator. Reason I ask is that I run the JCW w/o resonator and it actaully sounds better now.
Really looks great and you can't beat the price. Seems to be better than the OBX.
Thanks.
Old Jun 28, 2010 | 05:39 PM
  #39
plasticknives
No complaints. Adjusted my driving a bit to avoid droning. No leaks that I am aware of. Still love the tone and more pronounced burble. Been too lazy to adjust the tips or hangers.. I'll get around to it eventually.
Old Jun 28, 2010 | 05:46 PM
  #40
-=gRaY rAvEn=-
Moderator
Any thoughts on a resonator delete ?
Old Jun 29, 2010 | 12:25 AM
  #41
howsoonisnow1985's Avatar
howsoonisnow1985
Wow why debate a $1000 system.
Old Jun 29, 2010 | 04:54 AM
  #42
plasticknives
Honestly I'm not sure how that would affect it. It would be a pretty easy chop and weld, however.
Old Jun 29, 2010 | 01:20 PM
  #43
andyk30's Avatar
andyk30
Its a Invidia style exhaust
Old Jun 29, 2010 | 01:44 PM
  #44
-=gRaY rAvEn=-
Moderator
Yeah, just wondering if that was a viable solution to eliminating the "drone" you said it had at low RMP's.
Old Jul 12, 2010 | 01:36 PM
  #45
ImportFreak
Wow, finally got mine and installed it. The sound is perfect, exactly what I wanted. Its not too loud and not too soft. Mine has been on for a week, the drone volume varies on the weather. Installation was a breeze, removal of the old system was not, lol. Also installed a B&M short shifter while I was down there, made it a lot more simple. Overall, best bang for your buck exhaust in my opinion. Unless, your looking for HP and weight loss gains. Thanks all for your input.
Old Jul 15, 2010 | 12:50 PM
  #46
YMINI's Avatar
YMINI
Has anyone installed it on 04-06 model yet? What is the difference between 02-03 and later model? Will it be a difficult to instal exhaust for '02 on the 05 model?
Old Jul 16, 2010 | 09:26 AM
  #47
JumpingJackFlash
'02 to Dec. '03 is one range; Jan. '04 to end of '06 production is the other. You have to specify your month/year or you may end up with the wrong kit.
ImportFreak, temperature and humidity always affect exhaust tones. The Flowmaster setup I had on my old '05 Monte Carlo SS always sounded better on humid/cloudy and rainy days.
Old Jul 16, 2010 | 11:27 AM
  #48
plasticknives
The inner hangers on the mufflers face a different way. You would have to cut and reweld them (or torch and bend) to make it work.
Old Jul 19, 2010 | 11:43 AM
  #49
dannystyle254's Avatar
dannystyle254
hp gains
so does anyone feel power gains at all or is this system just for sounds??
Old Jul 19, 2010 | 12:04 PM
  #50
ImportFreak
Power gains? Um.....if there is, its very slight. You feel something, but no much. You maybe get 2-5 HP gain, but you would have to dino it to prove it. I would say its more for sound and looks.
