Drivetrain Spark plugs
Old Apr 18, 2010 | 10:12 AM
miniinhd's Avatar
miniinhd
Spark plugs
have a 2008 mcs (STOCK) what is the best plug replacement and what is the gap on them When do you have to replace air filters and has anybody used a K&N replacement filter and what about a cold air filter i believe its called typhoon by K&N MOVING ON MINIINHD
Old Apr 19, 2010 | 08:25 AM
slinger688's Avatar
slinger688
NGK ILZKBR7A-8G
Old Apr 19, 2010 | 08:26 AM
slinger688's Avatar
slinger688
BTW, take a look at this thread too.
https://www.northamericanmotoring.co...-plugs-eh.html
Old May 20, 2010 | 03:06 PM
miniinhd's Avatar
miniinhd
spark plug socket
hello thanks for reply BUT WHERE can you get a sparkplug socket for these sparkplugs I read where they are 14 mm 12pt socket ????? THANKS MINIINHD
Old May 20, 2010 | 03:54 PM
Porthos's Avatar
Porthos
Most sprak plugs now are pregapped. Plus read down at the bottom of that 1st page on the link and it tells you where to get the socket.
Old May 20, 2010 | 05:30 PM
slinger688's Avatar
slinger688
I use a 3/8" 14mm 6 point deep socket from Sears with a little rubber insert to hold the spark plug.
Old May 20, 2010 | 05:34 PM
iwashmycar's Avatar
iwashmycar
the advantage of a k&n would mainly be you can clean it and use it forever. unlike the stock paper ones that i think should be replaced every 30K depending on driving conditions.
check the marketplace
Old May 20, 2010 | 05:40 PM
slinger688's Avatar
slinger688
delete ...
Old May 23, 2010 | 03:55 AM
czar's Avatar
czar
If you want a better plug than either the Platinum or Iridium, then the Brisk Silver racing plug is the one to use.
eliseo1981
May 10, 2016 05:19 AM
CRC
Sep 14, 2015 07:27 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
