Drivetrain Completely
Old Mar 31, 2010 | 02:15 PM
Mini Tyler's Avatar
Mini Tyler
Completely seal the CAI
So I took a look at my ALTA CAI with box top and I do see that there are some small gaps in a few spaces that would be letting in some hot engine air in, and have the intake drawing air from places it shouldn't. What type of material that will resist engine temps should I use to seal this box up completely?
Before you respond, I do understand that the box will heat up because of engine temps; I am concerned with sealing it so the only air being sucked in is fresh air coming from the cowl.
Old Mar 31, 2010 | 06:41 PM
Fatherdeth's Avatar
Fatherdeth
Silicone
Old Mar 31, 2010 | 08:58 PM
Mini Tyler's Avatar
Mini Tyler
is there a foam in a can like spray that i can use to get to those hard to reach spaces?
Old Mar 31, 2010 | 09:21 PM
Longboard Mini's Avatar
Longboard Mini
I wouldn't worry. Either way your HP is going to be the same. That little bit isn't going to do a thing either way.
LB
Old Mar 31, 2010 | 09:34 PM
Motor On's Avatar
Motor On
Here's a thorough thread on improving the CAI insulation.
https://www.northamericanmotoring.co...-findings.html
Too little, heat soak sets in quick but it clears out quickly once moving
Too much, heat soak takes longer to set in but lingers extensively.
Right amount delays heat soak and cools as rapidly as one with little insulation.
When moving over 40ish MPH you're relatively unaffected, which is why HAIs do almost equally as well with a fraction of the cost.
But it's always possible to build a better mouse trap.
Old Mar 31, 2010 | 09:42 PM
fishead # 1's Avatar
fishead # 1
Foam & insulation
There are a Zillion different "foams" out there and temps are of little consequence. The lesser expanding foams ARE the way to go IF you need to use one ; they ARE VERY messy and even worse to "work" with (all foams) .If you do use the foam let it set up 24 hrs min THEN trim or remove any excess of which there'll be for sure. After it "sets --very simple trim & cleanup. The silicone IS better (heat rated) if its just small cracks to fill--good stuff--same idea on the set/ trim etc.CLEAN ALL FIRST (alcohol))If your try to SEAL --like top to box especially; the lesser expensive plumbers pipe insulation (split rubber) IS the ticket. Super easy to work with--pre cut all; mitre the corners , dry fit /test fit /ALL the pieces then after your good to go remove the adhesive tape ( if you want permanent) and VOILA !! FINI That insulation WILL form to "irregularities / clearences "etc as its really "malleable" & heat is no problem (it WILL BURN) A "perfect job is most likely gonna combine at least 2 of the aforementioned=== PERFECTION
Old Mar 31, 2010 | 10:02 PM
Longboard Mini
Wow
Old Mar 31, 2010 | 11:41 PM
fishead # 1
longboard
Other then giving Tyler EXACTLY what HE asked for is there some problem I'm unaware of ?? Personally I think you've got a h*** of a nice ride & I don't think it got that way by doin ANYTHING half A**------if I'm wrong -straighten me out . I HAD really wanted to ask how the rotrex thing was hapnin --------$$ don't buy happiness though I've got enough of both to discuss it a bit if you'd care to.
Old Apr 1, 2010 | 09:02 AM
Mini Tyler's Avatar
Mini Tyler
Thanks for all the responses. my whole thought is thinking of the intake as a vacuum....if there are multiple holes along the pipe inlet, the suction at the primary inlet (and what should be the only inlet) it wouldn't be as powerful as it could (at least thats what my brain tells me). I will try some silicone and some rubber trim and see if I can squeeze my giant hands down into those small spaces.
Old Apr 1, 2010 | 09:12 AM
ALTA_Jarid's Avatar
ALTA_Jarid
Hey Tyler,
PM me a picture of your intake setup if you can. I might have a seal for the top of your box- to boxtop!
Old Apr 1, 2010 | 09:49 AM
fishead # 1
XZAKLEE
Ty : You've definitely got the brain workin correct-------do it YOUR way-------it's THE RIGHT way !!
Old Apr 1, 2010 | 10:07 AM
Mini Tyler's Avatar
Mini Tyler
Thanks Jarid, I'll PM pictures to you when I get home from work
Thanks Fishead
carid
Dec 28, 2025 04:11 AM
Oct 19, 2015 08:07 PM
Sep 10, 2015 10:52 AM
bbak11010
Sep 7, 2015 08:08 PM
bbak11010
Sep 7, 2015 08:03 PM
