Drivetrain VVT Question
VVT Question
By any chance, does the VVT/VANOS/WIGGITIZER on my '08 MCS start actually changing the intake valve timing at about 4500rpm or is it a continuous change right across the whole rpm band? I've been led to understand that variable valve timing only comes into effect at higher rpm's. Am I right on this? Trying to pin down a power drop-off that's starting at ~4500rpm. Thanks for any help.
The cars that have brought about the "it only kicks in at high rpm" idea are cars with traditional VTEC setups, where the system is essentially just a second camshaft or set of lobes that the engine changes over to at a fairly specific rpm.
Ahh... intake side. I knew it was one or the other and that it was simply VANOS, not Valvetronic.
Grizld700
Dec 30, 2015 10:47 AM
Navigation & Audio How much power do you get through the Y-cable--and can it be increased?
twriter
Oct 2, 2015 03:14 PM
