Drivetrain Fluttering/Ticking noise coming from engine bay
Old Mar 16, 2010 | 12:06 AM
jollyroger927's Avatar
jollyroger927
Any one have any idea why i hear a fluttering/ticking noise when im boosting(WOT), coming from the passenger side of the engine bay?
Upgrades:
17% pulley
alta catback
alta intake
alta tensioner stop
Old Mar 16, 2010 | 05:48 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Year? Mileage?
some possibilities:
SC going bad / lost oil
Crank pulley / damper starting to fail
Valve lifter noise
Old Mar 16, 2010 | 07:17 AM
Helix13mini's Avatar
Helix13mini
More description needed. Does it happen only when engine is under load? Can you hear it when revving in neutral? If so, have an assistant rev the motor and see if you can locate the source of the ticking. If not, maybe you are hearing pinging, and need to examine the fuel you are using...
Old Mar 16, 2010 | 03:06 PM
jollyroger927
70,000 miles, 05 cooper s
Ill try reving it next to a wall later, i use shell gasoline btw, 93 octane.
I was thinking maybe the supercharger was going bad but im not too sure on what that would sound like. And would it be the actuall supercharger going bad, or just the water pump gears?
Thanks for the help.
Old Mar 18, 2010 | 09:43 AM
jollyroger927
I couldnt hear it happening when i wasnt moving. Just reving. I also noticed you really only hear it when WOT. Even if im 50% on it, and boosting, you wont hear it.
Old Apr 19, 2010 | 07:29 PM
Koreanadian's Avatar
Koreanadian
The motor mount maybe?
Old Apr 19, 2010 | 08:11 PM
jollyroger927
I searched through some forums and matched my noise from what people were saying, as the crank pulley noise. When the crank pulley pulls apart into 2 peices. Not sure how to describe it as i almost dont understand it. But it seemed like ppl choose to live with it or replace it.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
willybudista
Aug 15, 2015 06:13 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
