Drivetrain I abso-FREAKN'-lutely love my new DoS intake!!!
#105
on
DoS is recommending that folks take some denatured alcohol or brake cleaner and clean-off the outside of the turbo inlet and the inside of their 'S' or JCW inlet hose if this slipping issue occurs to you. It should allow the hose to get a better purchase on the turbo by removing surface oils.
-Clint
#107
on
I got the clamp in the mail today. I put it on and it seems to be doing the it's job nicely.
Thank you Clint for being a stand up guy and taking the time to help me figure this thing out.
I wouldn't hesitate for a second before buying more parts from you. Great customer service to back a great product.
#108
on
So which R56 JCW owners would like a mini-t-bolt clamp for their turbo inlet/intake hose? (Please drop me a PM so as not to hijack Tim's thread.)
As I mentioned to Tim in the emails that we exchanged, I'll need any JCW owners who want a clamp to do the following before installing the clamp.
Clean these areas with brake cleaner or denatured alcohol:
1) Turbo inlet hose barb (aluminum barb coming off the turbo)
2) Turbo inlet hose grommet (remove this from the turbo inlet tube and clean both sides if the grommet
3) Inside of turbo inlet tube (clean mating surfaces for turbo inlet hose grommet)
Thanks again to Tim and Elie for helping me to fix this issue ASAP.
Best,
-Clint
Last edited by Mini'mon; 04-13-2010 at 09:05 PM. Reason: forgot the word 'like' after the word "would"
#110
The catch-can is not associated with the DoS CAI directly. The two are discussed in conjunction as the mounting location of the DoS CAI precludes mounting the catch can on the firewall on the driver's side of the engine bay. There are other options for mounting the catch can.
#111
on
BSH makes a great catch can, but there are others available.
Seafoam has been a popular option for this carbon buildup issue, but it is not rated as sensor safe. I would not use it. Chad at Detroit Tuned located a sensor-safe treatment called BG 44K that has the same benfits of Seafoam w/o the sensor issues. These treatments remove any vapor or spent oil (carbon) that makes it past the can and gets deposited on the valves.
You can check out more about this on episode #330 of White Roof Radio.
#114
on
RE: Using the R56 JCW Inlet Tube on a non-JCW R56 MCS
Although the non-JCW R56 MCS turbo inlet is indeed just slightly smaller, The R56 JCW turbo filtered air inlet tube will fit the non-JCW R56 MCS!
If you'd like to use this part on your R56, we STRONGLY recommend that you:
A) Clean these areas with brake cleaner or denatured alcohol:
2) Turbo inlet hose grommet (remove this from the turbo inlet tube and clean both sides of the grommet
B) Use a special narrow mini-t-bolt hose clamp (available from DoS) to attach the JCW filtered air inlet tube to the turbo. This special hose clamp is recommended whether you install the DoS CAI or are running the factory airbox. It can generate significantly greater holding force than the factory clamp to keep everything neatly in place for this mod.
#115
So what R56 JCW owners would a mini-t-bolt clamp for their turbo inlet/intake hose? (Please drop me a PM so as not to hijack Tim's thread.)
Best,
-Clint
#116
#117
on
Clint,
I'm impressed with your constant feedback and posts. So, I just pulled the trigger on this along with a the saw loaner and a delete kit. Please send me the upgraded clamp for the JCW's. Please, please, please get this on a truck to me ASAP! Would love to have it to install it this weekend. Thanks in advance!! Can't wait!
G
G
#119
on
I'll be creating a new 'JCW intake kit' listing to the DoS site that includes this clamp for the JCW turbo inlet tube. The clamp will add a few bucks to the cost of the JCW intake kit, but the clamp is small, mighty & holds amazingly well.
All existing DoS customers with JCW's will get the clamp for free provided that they request it.
Any R56 'S' customers that do the JCW intake tube mod can buy the clamp from DoS for $7.00 + shipping.
#124
I will shoot another video later today or tomorrow and post it in this thread but this time I will start from first gear and then accelerate so you can hear the full range of "music" as I row through the gears.
That flutter during the turbo blow off definitely takes some getting used to but then again it took a while to get used to the turbo sounds when I removed the stock air box in the first place.
Like I said in the video, Jan acquired that manipulation of the blow of valve from the MINI Challenge car. It would have been nice post tune to say this is what I did to your car, this is what it will feel and sound like. Rather than me running around trying to figure out what that crazy sound is. He did do some of those things but it was crazy at Helix that day and I needed to jet outta there and head up to Boston for business.
Clint, you make a great product and its nice to see you post regularly on NAM. You are a real stand up guy. I defiantly enjoyed our phone conversation last Saturday. We really should talk again soon and get Tim on too.
