Drivetrain Whats next? on the mod list
Old Mar 6, 2010 | 08:01 PM
laxpimp6903's Avatar
laxpimp6903
ive got an 04 that ive just finished putting an Alta CAI, 15% pulley, One Ball, and colder plugs. for suspension ive done the alta 22mm rear sway bar. What should i do next. Primarily i just drive the street, maybe a little more spirited then the law allows, but i plan to drag it in the near future.
Ive been considering the following, kind of in order, but not sure what I will get the most benefit from. and im not limited to this list. looking for the most benefit, speed or handling.
lowering springs (H-sport, M7 or TSX) with control arms
Tune (live in Tampa Bay, FL not sure where to go)
header (megan or obx, cant afford others)
injectors
CAM
intercooler or air diverter for stock
What should i do next? I figure i have around $500 and realize some of the above dont fit that budget.
Old Mar 6, 2010 | 08:15 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
LSP's would lower center of gravity and provide some handling advantages to go along with your added HP.
Then I would possibly consider upgraded brake kit for added stopping power.
Set of nice rims maybe.
Old Mar 6, 2010 | 08:20 PM
laxpimp6903
thats what i was thinking but im having a hard time deciding on which springs. the TSX seem to be very highly liked, but i dont like that they drop the car less than an inch. I like the M7s for the 1.3 inch drop, but some say that is to much and that the M7's are too luxurious. H-Sport appear to fall somewhere in the middle. i dont understand spring ratios so i just have to go on what others say.
Old Mar 6, 2010 | 08:58 PM
-=gRaY rAvEn=-
Moderator
Start looking up thread here on springs.
Look up the difference between progressive and linear rate springs. Find the thread, "show me your lowered mini". It's a few pages long. Most of those guys are still on the boards here and would be more than willing to give you their opinions on their spring set ups.
Living in NE, I went for little over 1/2 inch drop with the Factory JCW Sport Susp. Even dropping 1/2 inch I have irregular rear tread wear requiring the purchase some day of adjustable rear control arms.....so you may want to add that to the list as well unless you have a large tire budget planned.
Old Mar 6, 2010 | 09:33 PM
laxpimp6903
i fully intend on getting rear lower control arms.
Old Mar 6, 2010 | 09:44 PM
phungshum's Avatar
phungshum
I heard that headers aren't really useful for mini coopers. But a detroit tuned bypass valve would be a lot of fun!
Old Mar 7, 2010 | 12:40 AM
howsoonisnow1985's Avatar
howsoonisnow1985
injectors
CAM
Other than springs, I would give an HPDE a shot. Much funner that a Drag.
Old Mar 7, 2010 | 03:57 AM
drsilvermini's Avatar
drsilvermini
My RMW Header and Cam gave me a a nice bump in power. My suggestions laxpimp6903 would be injectors, cam, tune.
Old Mar 7, 2010 | 07:16 AM
mini_macky's Avatar
mini_macky
i'm also in the same boat as you are with regard to the power mods planned (cam, header, tune) but i see myself getting just the tune sometime this year as i think it would be the best bang-for-buck mod.
for suspension, the only experience i have is with Eibach pro-kit springs. a bit on the bouncy side for me
for brakes, stainless steel lines & better pads oughta do it
Old Mar 7, 2010 | 08:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I'd say go for the TSW springs and some Hsport control arms That will lower your car, improve your handling and still give you a good if not better ride.
Old Mar 8, 2010 | 01:14 AM
laxpimp6903
Way, those are what I was looking at but, I was also considering, since I'm quite happy with the handleing of the car already, that I might do injectors, a DT bypass valve and cone have u tune it. What is the approx cost to have u tune it?
Old Mar 11, 2010 | 03:23 PM
metaltometal's Avatar
metaltometal
Wrap your car in Carbon Fiber Vinel.....
bADbOYbECK
41
Oct 16, 2015 12:39 PM
sempaipaul
Sep 9, 2015 05:55 PM
Sep 8, 2015 11:37 AM
OutMotoring
Sep 8, 2015 06:27 AM
larryd96
11
Sep 8, 2015 05:01 AM
