Drivetrain Alta tensioner stop install ?'s
Old Mar 25, 2009 | 10:32 PM
Vernon29RW's Avatar
Vernon29RW
Hey everyone,
I just received an Alta tensioner stop today....the instructions from Alta say to remove ALOT of parts from the engine including the supercharger pulley! Is it really necessary to remove all these parts?? I was under the impression that you can just remove the pass fender liner and slip it on through the wheel well. no?? Anyone know of a place that rents out the belt tension release tool?? Seems stupid to buy the tool for $100 to use it once or twice! Thanks everyone...hope to hear some good advice.
Steve
Old Mar 26, 2009 | 05:13 AM
tagger99's Avatar
tagger99
Correct, I put one on a month ago as well as a belt, remove the right front wheel, and the fender liner and slip it on through the wheel well.
It is fairly simple, I made my own tensioner tool.
Old Mar 26, 2009 | 06:07 AM
Mike S's Avatar
Mike S
I removed the right front wheel and fender liner. Was 10 mins to do and then loosen the screw and slide on the tensioner stop. Very easy. Alta's method is too complex.
Old Mar 26, 2009 | 07:14 AM
Bigshot's Avatar
Bigshot
Yep no need to even use a tensioner tool. Even helped a friend do it w/o removing the fender liner.
Old Mar 26, 2009 | 07:36 AM
Vernon29RW's Avatar
Vernon29RW
kewl that's what I thought...thanks everybody. I was going to change the belt too while in there putting the stop on. I just wish I knew how you guys did it without using the tensioner tool...I dont even get how that freakin thing even works! No one knows a place that rents it out though do they?
Steve
Old Mar 26, 2009 | 08:35 AM
Bigshot's Avatar
Bigshot
Do you have a club locally? Most clubs have at least one member with one.
And you want to put on a new 535 NAPA belt with the 15% you have.
Old Mar 26, 2009 | 09:48 AM
Professor's Avatar
Professor
Careful with the Alta stop. Mine is suddenly missing from the engine?! I think its where it only bolts on to one bolt and worked its way loose due to the rubber bushing under it.
They work good just keep an eye on it.
Old Mar 26, 2009 | 06:16 PM
Vernon29RW's Avatar
Vernon29RW
Actually I have a 17% and that was the next thing I was going to ask you guys...there seems to be alot of confusion as to what belt to run for what size reduction pulley.
Old Mar 26, 2009 | 07:22 PM
Mike S's Avatar
Mike S
You must get that 65 belt, 69 is too big for 17% even though that's what it states on the Alta website.
Old Mar 28, 2009 | 06:17 PM
MUShadd's Avatar
MUShadd
i believe www.autoxcooper.com rents out tensioner tools for free. if you want to own one of your own...as youll need it again with every belt change..there are a couple on eBay right this second for about half the price of a new one...
heres autox one... 15 bux to ship, 100 refund once u return in 30days. and you gota pay to ship it back of course...but not a bad deal.
http://www.autoxcooper.com/alta_gomi...7-engines.html
Old Mar 31, 2009 | 12:05 AM
Vernon29RW's Avatar
Vernon29RW
thanks man that's what I was looking for...the ebay is 65 buy it now but with 13 shipping its almost the same as anywhere else. It looks pretty easy to make up with a couple strips of stock steel....crazy they want $100 bucks for the stupid thing! LOL
Steve
Old May 19, 2009 | 07:30 AM
feedDunk's Avatar
feedDunk
I just installed mine and now it's gone, in 2 days! The bolt that holds the tension damper is now gone. Any idea on what that bolt is? Do I need a whole new assembly? Can I just replace the bolt?
HELP!!!
Old May 19, 2009 | 08:32 AM
feedDunk's Avatar
feedDunk
Ok, talked to mini parts guy. It is a 6x35 hex bolt. He said run to Lowes and you should be good. Still nervous!
Sorry to jump on this thread, but it was the closest to my issue.
Old May 19, 2009 | 07:44 PM
Mike S's Avatar
Mike S
I don't think you tightened it properly. I have had this tensioner stop on my car for more than 4000 miles and it's still there.
Old Mar 5, 2010 | 08:50 PM
AAhmed007's Avatar
AAhmed007
Hey does anyone get a rattle with the alta tensioner stop? if so, what have you done to remedy this? thanks
Old Mar 6, 2010 | 08:03 PM
Mike S's Avatar
Mike S
use electrical tape and wrap the tensioner stop once or twice and it should be fine.
Old Mar 8, 2010 | 01:39 AM
Vernon29RW's Avatar
Vernon29RW
nice tip Mike, I still haven't even gotten around to changing my belt and putting this thing on. Summer was a total bust last year...really got nothing accomplished on the car But I'm waiting for the warm weather to come back around here so I can finish up some projects I never started! LOL
Steve
Old Mar 11, 2010 | 07:22 AM
Mike S's Avatar
Mike S
Hahaha, only here to help
Tell me about it, my chargecooler finally arrived this week. I hope I can get it all done on Saturday!
Old Mar 11, 2010 | 12:41 PM
MINIsurf's Avatar
MINIsurf
I attempted to put the one from Way Motor Works on and thought I needed the tool to take the tension off. Once the wheel liner is out you cant just throw the tensioner stop on there due to the sub frame in between the wheel well and the pulley. How do you do it with 2 people and no tool?
Old Mar 12, 2010 | 05:12 AM
Vernon29RW's Avatar
Vernon29RW
hmmm wish I had done mine already so I could help you out....did you try to get to reach down from up top and have a friend guide your hand from underneath? Maybe you can get a better angle on it from up top but obviously you won't be able to see what you're doing hence having the buddy there to help guide you. Just a thought....
Steve
Old Mar 12, 2010 | 06:30 AM
shorty_du_op's Avatar
shorty_du_op
I just put one in, and it was cake. 13mm ratcheting wrench helped a lot, but a regular box wrench works too.
Old Mar 12, 2010 | 07:23 AM
MINIsurf's Avatar
MINIsurf
You did it by yourself? How did you take tension off the belt?
Old Mar 12, 2010 | 08:38 AM
shorty_du_op
I did it with the belt on... I don't think you have to take it off...
Sexual Chocolate
Mar 31, 2019 08:02 PM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
12magnum
Aug 31, 2015 08:22 PM
