Drivetrain My Plans (input needed!)
Old Mar 25, 2010 | 12:58 PM
  #26
fishead # 1's Avatar
fishead # 1
You CERTAINALLY DON'T want to do it "later"---- you should put "lockers on those header bolts also---should be able to reuse all your existing (ex header) but figure you're GONNA have a bit OVER 2 bills just w/this----though NOW is the time !!There are better & worse brands---I wouldn't sweat it (no alta)
Old Mar 25, 2010 | 01:04 PM
  #27
ZippyNH's Avatar
ZippyNH
Personaly, I would invest in the suspension, then you skills....then when you know how to use even more power, do the header!!
If you do the header...be prepared...installs are not all trouble free...many throw codes...from the motor running lean, or having poor quality/no catalyatic converter...so you may need to buy an o2 similator to make the car run code free, and right....even with a tune....
I would talk to a vendor and see what product they like to use....a little bit more $ might save you tons of problems later!!
Old Mar 25, 2010 | 01:35 PM
  #28
fishead # 1
header
Wouldn't bother w/o the head though IF you're doin it (head) NOW is the time ! COOLER PLUGS $$ (gooduns)
Old Mar 25, 2010 | 01:39 PM
  #29
fishead # 1
ZIPPY IS RIGHT--------But a guys gonna do whata guys gonna do !! Hey ----its just $$$ (yours) heh heh
Old Mar 25, 2010 | 07:03 PM
  #30
Un0RiGiNaL's Avatar
Un0RiGiNaL
Headers are simple bolt-on. Why would they throw a CEL? They connect to your stock catpipe, theres the pre-cat sensor location on the header and a post cat sensor after the catpipe am I wrong?
Why else would they make the motor run lean? Im not getting a trackpipe and header, just the header to replace my stock one.
Im buying performance parts now and suspension later because Jan from RMW is coming to my area on april 25th and I want to get a tune from him, and I want to get all my parts before the tune so i dont need a retune.
And i already have colder plugs Fishhead, they came with the pulley kit. Im not doing a head, im doing headers. I hope you didnt mix those up cause a head costs like 2000$ and headers cost like 200$
Old Mar 25, 2010 | 09:30 PM
  #31
yellowbritishrocket's Avatar
yellowbritishrocket
they dont connect to the stock cat pipe they are one piece with the cat built in so if you put in a obx one youll likely lose the cat unless they now come with them built in...just remember you get what you pay for...if the cat isnt exactly right for the o2 sensor it will throw codes...this is a problem even the high dollar ones have had issues with...if you really want an exhaust try to find a used one if need be...there are just some things that you have to come to terms with and bite the bullet on
Old Mar 25, 2010 | 09:36 PM
  #32
Un0RiGiNaL's Avatar
Un0RiGiNaL
Oh damn I could swear i read somewhere that the OEM catpipe/headers are separated by a flange. I guess im not gonna get a header. Ill just look for intake and exhaust.
I have been searching for exhausts for ages though and nobodys selling them. at least not on NAM.
Any other big MINI forums out there with good classified sections?
Old Mar 25, 2010 | 09:51 PM
  #33
fishead # 1
You'll never get OVER the "wall" by bangin your head into it---------Y.B.R IS 110% RIGHT. IF all you want is "instant gratification"--- buy a sprint booster the $$ is about the same, it'll take you 5 minutes and YEEHAW then get back in line & take your lickins----sounds like there WILL be many. Become a Blues Fan & MOTOR ON !!
Old Mar 25, 2010 | 09:53 PM
  #34
Un0RiGiNaL's Avatar
Un0RiGiNaL
lol
are you high?
Im not looking for instant gratification, im looking to get all the parts neccessary before i get my car tuned. because tuning isnt cheap.
Old Mar 26, 2010 | 04:44 AM
  #35
stevecars60's Avatar
stevecars60
Originally Posted by Un0RiGiNaL
lol
are you high?
The OE header is very underated. The OBX is a lot of work for little gain, you also lose the cat. IMHO, it makes for more unwanted cabin noise than performance. I'm running OE w/Cosworth head & 380s - Invidia cat back.
FYI - the Sprint Booster is worthwhile. 3 of the best, most respected, contributers on this forum use it. You can do a search.... I have 1 & it does what it says, even on top of a tune.
A 19mm rear bar is all you need, DD, if your car has the sport suspension - it's the iceing on the cake.
Nothing wrong with the Blues, I'm a fan.
Old Mar 26, 2010 | 08:58 AM
  #36
Mach V Dan's Avatar
Mach V Dan
Sprint Booster is a throttle re-mapper. It changes the function of pedal angle to throttle body angle, nothing more. It makes the car "feel" faster at light throttle because it's opening the throttle more aggressively at low pedal angles. You can actually do this yourself by...stepping on the throttle harder.
Just trying to be clear that that device does NOT add horsepower to the car.
--Dan
Mach V
Old Mar 26, 2010 | 11:09 AM
  #37
ALTA_Jarid's Avatar
ALTA_Jarid
--Dan
Mach V
It's that simple!
Old Mar 26, 2010 | 11:34 AM
  #38
jimz68's Avatar
jimz68
You don't lose the cat with a OBX header.
Header comes with a flange to adapt to your stock cat. Any competent exhaust shop should be able to weld this.
Jim
Old Mar 26, 2010 | 12:21 PM
  #39
stevecars60
Jim
You're correct, should have said pre-cat
Old Mar 26, 2010 | 12:42 PM
  #40
Un0RiGiNaL's Avatar
Un0RiGiNaL
Jim
Any issues with CEL's?
Old Mar 27, 2010 | 06:57 AM
  #41
stevecars60
The Megan header is worth a look. WayWorks - post 2 this thread.
eliseo1981
Jan 28, 2021 02:45 PM
boostedhaze
Jan 2, 2018 07:26 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
noreen99
Aug 8, 2015 08:21 AM
