Drivetrain BSH catch can and dual boost port install
#326
Cleaning isn't really the issue (the boost tap acts as a blockage; cleaning wouldn't make it block more or anything) ... it's weather or not the pressure increase in the crankcase would be enough to cause long-term reliability issues.
Personally, I'm not comfortable blocking that line, so I didn't. But a lot of people are, and I haven't seen anyone reporting leaking gaskets yet.
so its basically I have to decide if I want to take the chance of having gunked up valves over time and leaving the pass side pcv open or possibly leaking gaskets down the road and plugging it with the dual boost tap?
hmmm, i wonder what repair would cost more?
#328
Apparently BMW doesn't think 2 PCV tubes are required. The 2011 MCS has only one. It would be nice if someone could pull the cam cover off a 2011 and see if they've put some kind of baffling in there to try and trap the crankcase fumes. Ford is already doing that on their DFI engines. Volunteers?
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
#329
#330
I talked to the shop foreman at my local MINI dealer, last Monday, about using an oil catch can. They are very mod friendly there. He said that he has seen a few cars with oil catch cans come through the shop and that none have caused any problems.
We also discussed the 2011 MINIs. He said that the new ones have a different head with passages that run from the head cover to the intake ports, there is also a different cover, with four O rings to seal those ports to the cover.
This is why there is no hose from the cover to the intake manifold anymore. He said that there had been a problem with oil pooling at the throttle and the new head is MINI's fix.
Dave
Dave
#331
understood.
#332
#334
Dave
Dave
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
#335
#336
http://store.42draftdesigns.com/PCV-...tic_p_322.html
... but I'm sure you can find similar elsewhere.
Also, I wouldn't recommend the hose they supply (and that's shown in the picture I posted). I had trouble with it starting to collapse under the vacuum; ended up replacing it with some fancy (and fairly expensive @ around $8/ft) metal reinforced vacuum hose. I've been really happy with the new stuff, so far.
that is a very nice setup. is that a DD42 OCC? how did you run the lines to the intake and driver side intake ports?
I bought an extra crankcase ventilation hose from the dealership (so I could keep the original if I wanted to go back... and so I could work on something not coated in oil), and tore it apart for the end fittings. Worm-clamped hose to those fittings, and swapped them (one's right-angled, the other at about 45 degrees to ease with the new hose routing.
http://fishbert.imgur.com/catch_can_installed
Right now I don't have anything on the CAI-to-valve-cover line, but I plan on addressing that in the near future... well, maybe after I get the time/motivation to take off the intercooler and clean it out first.
While I haven't had a chance to look at the inner workings of a valve cover (old or new), I understand that part of its function is to act as a vapor separator to keep oil and such out of the intake ports. If that's actually correct, it hasn't exactly worked as intended to date... but maybe the new one will buck that trend. I suspect the only way we'll know for sure if carbon buildup is still and issue on the N18 engine is to wait a bit and find a 2011 MCS owner who wants to pull the intake and take a peek.
#338
My primary concern has been carbon buildup on the intake ports. The CAI side doesn't have anything to do with that... just that some people have found oil collecting in their intercoolers from the fumes that escape that way under boost conditions. It's a concern that I plan on addressing with a 2nd can in the future; but it's not a priority at the moment.
#339
I custom blocked the TB side pcv and have a catch can, clean as a whistle! Most of the carbon issues relate to cars that are not rev'd through the ranges and the air/pcv gases do not travel at high velocities enough through the system. to be burned off completely. Horrible design but you can remedy it.
#340
#341
on
BigPR, You blocked the turbo side and have a can on the back side like Fishbert? Are you concerned about the blockage causing any leaks. I just removed my boost port tap plug because I am concerned about causing leaks. So now I need a second catch can....
#344
No TB as in throttle body
the intake manifold side works under vacuum which is 75% of your driving once blocked your good to go.
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
#345
If you completely blocked off the pcv system* it would cause a blow in the valve cover gasket, you still have venting per the intake side(catch can location).
Also helps a ton with the sooty bum
#346
I can't speak to what BigPR is doing, but I'd like to clarify and say that I don't have anything blocked off.
That said; blocking the driver side line from the CAI wouldn't be a problem... except the car is turbocharged. If that line were blocked off, blow-by gases don't have anywhere to go under boost and would momentarily pressurize the crankcase much more than having the boost tap blocking the other side would.
EDIT:
while I was writing the above, it seems much of it was already answered.
#347
I blocked the vacuum side all together
i cant think of any long term effects at all, what effects were you referring to?
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
First off, you should probably put the plug back on until you actually get a 2nd can. The (theoretical, mind you) risks of blocking that line are more of a long-term concern, which I would think is out-weighed by the carbon buildup issue.
I think he's talking about leaking gaskets from a pressurized crankcase. It's a possibility that doesn't make me comfortable with using a boost tap to block the crankcase ventilation hose on my car... but as I've said before, I don't think I've ever heard of anyone actually experiencing a problem with it.
EDIT:
You should call them back and ask them to post to NAM again. They used to be really active in some very interesting threads; even working with NAM folks to improve their catch can design in one. Then their accounts were marked as 'banned' (no clue why) and they stopped posting. The accounts don't appear to be banned any more (again, not sure why), and I sure think it'd be nice to see them around here again.
EDIT:
#350
I see where your coming from but all that is being done is the vacuum is not present, boost pressure seen at the valve cover is the same either way. I see the running rich theory but the ecu will compensate to a great percentage to over come that. I havent seen the smoke problem yet(knock on wood) but that is in no way a negative effect, Nothing is being hurt by the blockage. When you block the pcv(passenger side) all your doing is getting rid of the vacuum source. the valve cover still has an opening which vents which is why you will not blow a VC gasket.
I see where your coming from but i have to disagree on negative effects.
And having a white car and being a detailing junky the first thing i took notice of was that the rear was definitively less sooty.
