Drivetrain Just Installed: Dinan Intake
Old Apr 3, 2010 | 09:39 PM
  #26
scottie10014's Avatar
scottie10014
Had mine installed a few weeks ago now along with a 15% pulley. Soooo nice. I LOVE the noise. It's whines and sucks like crazy... hmm that's sounds a bit pervy, but anyway its great. :-)
Old Apr 5, 2010 | 09:40 AM
  #27
DuncanShea's Avatar
DuncanShea
Originally Posted by orbeamike
Is the Dinan airbox any taller than the stock unit? I also have a M7 strut brace which just clears the stock unit, I hope there is no interference from the Dinan unit.
any info on this is appreciated.
I have the Dinan COI and the M7 STB. Fit is just fine
Old Apr 5, 2010 | 10:28 AM
  #28
MiniMio's Avatar
MiniMio
Good to know, I'm about to get the M7 STB!
Mio
Old Apr 19, 2010 | 08:23 AM
  #29
Mini_Chan's Avatar
Mini_Chan
Any news on the ITG filters for the Dinan CAI? I need to replace mine soon, and I have no luck in finding a replacement.
Old Apr 19, 2010 | 08:48 AM
  #30
scottie10014
Haven't heard anything myself. Someone on a diff thread mentioned that there are K&N filters that are more or less the same as the original Dinan filter dimensions.
Old Apr 19, 2010 | 09:45 AM
  #31
ZippyNH's Avatar
ZippyNH
Why are you replacing it? If you use the correct foam cleaner (ITG makes a good kit, or any "foam filter cleaning kit")....it should be good for many years.....but if you use the wrong stuff (cotton gauze cleaning kit)....like K&N cleaner/oil, it will eat the foam......and the filter will not work....the oil is very different...one is much more sticky....
Old Apr 19, 2010 | 01:38 PM
  #32
MiniMio's Avatar
MiniMio
Isn't the Dinan a paper element like the K&N? I thought you could clean it like the K&N and reuse it at least once.
Please correct me if I'm wrong. Plus, K&N makes a similar size so it should fit as well.
Mio
Old Apr 19, 2010 | 02:22 PM
  #33
ZippyNH's Avatar
ZippyNH
Some folks clean and reuse the stock dinian filter....it looks like a blue K&N, but they call it disposible when you buy it. Many folks have replaced it with a foam ITG filter...K&N has a universal that will fit... A bit smaller, so it will need cleaning more often to matain the same flow...the stock filter has a bit of bend in the neck so a much bigger filter can fit in the airbox.
Old May 2, 2010 | 11:45 PM
  #34
Mini_Chan's Avatar
Mini_Chan
I was planning on replacing my original Dinan filter.
Old May 3, 2010 | 06:59 AM
  #35
Mini SUV's Avatar
Mini SUV
I installed the replace ITG filter in my Dinan intake about 4 months ago. This weekend I took the intake cover off to clean the filter and found that the ITG filter had broken off at the neck. I'm not positive it didn't happen when I was taking the Dinan cover off, but I may have been driving a while with no filter. The neck of the ITG filter is just glued on to the filter body. I wouldn't recommend the ITG filter. I cleaned the saved original Dinan filter with a K&A kit and installed it.
Old May 29, 2010 | 06:12 PM
  #36
WLSH BST's Avatar
WLSH BST
I bought an ITG filter to install in my Dinan CAI and while removing it from the bag the neck of it came away from the body of the filter making it useless. Seemed like they were poorly glued together. I returned it and used an angled generic sponge UNI filter instead.
Old Apr 14, 2013 | 04:06 PM
  #37
ZippyNH's Avatar
ZippyNH
Dinan Airbox Replacement Filter...
Now sold by waymotorworks!!
Replacement Filter for Dinan Intake for 2002-2006 R53 MINI Cooper S. If you have a Dinan intake on your R53 and need to replace the filter, this is your most cost effective solution. This K&N style filter is a direct replacement for the filter that came in the Dinan intake air box.
Sold as individual filter and includes one clamp.
http://www.waymotorworks.com/t-k-n-dinan-filter.html
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
