Drivetrain K & N air filter replacement
Old Feb 4, 2010 | 06:59 PM
MiniKar's Avatar
MiniKar
Has anyone with an 06 Mini S made the switch from the stock air filter to the drop in K & N air filter replacement ?
Not the cold air type, but using just the stock air filter holder...............
If so, any noticeable changes ?
Old Feb 4, 2010 | 09:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I did some dyno testing long time ago and we gained 3hp with just the drop in filter.
I've got em in stock if you need one.
Old Feb 4, 2010 | 10:26 PM
slocraiger's Avatar
slocraiger
I dropped one in about six months ago... easy enough job, stock one was FILTHY... don't know if it really made much of a difference though.
Old Feb 8, 2010 | 11:28 AM
rsvp9146's Avatar
rsvp9146
Understand that the K&N will probably get you a few horsepower at the expense of less filtration.
I'm a little wary of K&N's products as the oil in the filter can coat heated-wire type airflow sensors, causing problems.
I'd recommend using either the stock Mahle filters or ITG foam filters.
I find it interesting that K&N is now promoting themselves as a "green" company in print ads, claiming that a re-usable filter is more eco-friendly.
Old Feb 8, 2010 | 03:39 PM
Capt_bj's Avatar
Capt_bj
so exactly how does a driver 'experience' a 3 HP increase?
come ON people .... don't be dupe'd
I use K&N for the reusable and cleanable factor (green????) but the best is probably a simple paper filter
silence2-38554
98
Sep 21, 2016 02:52 PM
polotska
Aug 23, 2015 09:10 AM
pre shrunk
Aug 18, 2015 11:09 AM
minipopkart
Aug 13, 2015 05:22 AM
