Drivetrain Help! I think my s/c just blewi
Old Oct 8, 2009 | 06:48 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Blown Cylinder Head (Formerly "I think my S/C just blew")
I just started my car and a very loud pop rang out followed by sounds no engine should ever make. There was some smoke that seemed to come from the supercharger area, but by the time I got the hood up it had dissapated. Help!
Old Oct 8, 2009 | 07:19 AM
tazio's Avatar
tazio
Check your spark plugs...
Old Oct 8, 2009 | 07:27 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Why? To see if they were replaced with C4?
Old Oct 8, 2009 | 07:32 AM
stevecars60's Avatar
stevecars60
Because you may have blown a plug out of the cylinder head.
Old Oct 8, 2009 | 07:36 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Holy $$$$ ur right I've never seen that before what's that mean?
Old Oct 8, 2009 | 07:43 AM
stevecars60
It's not good.
This is a common problem. Did you change pluggs reciently? If so, they need careful attention when they're installed - especially Denso. There are some threads on the issue right here on NAM.
Old Oct 8, 2009 | 07:47 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Oh good a damaged cylinder head... Even better
Old Oct 8, 2009 | 07:49 AM
MaxMini81's Avatar
MaxMini81
Wanderer
It's not good.
No like 06 they're NGK
Old Oct 8, 2009 | 07:54 AM
jimz68's Avatar
jimz68
A competent shop can install a Heli-Coil or some other brand of thread repair device without removing the head. Check your local club for a good shop in your area. A nusance yes, but not that big or $$$ of a problem.
Jim
Old Oct 8, 2009 | 07:57 AM
MaxMini81's Avatar
MaxMini81
Wanderer
What about the dealer
Old Oct 8, 2009 | 08:28 AM
RatBlast's Avatar
RatBlast
welcome to the club ! my rmw head blew a plug as well. just ask around at shops . most shops should be able to do the job . the mini dealer charges way to much by the hour , i stay away from them at all costs. the bummer i found is when i went to re gap my plugs the heli-coil came out with the plug.
so when the day comes that i need to change plugs , i will need to do a new heli-coil at the same time.
Old Oct 8, 2009 | 09:12 AM
stevecars60
There are inserts available, not heli-coil. I have used these sucessfully for many years. A good mechanic, that has used inserts, can do this repair without removing the head.
This http://www.locknstitch.com/sparkpluginserts.htm is the best info I could find on a quick search.
Old Oct 8, 2009 | 09:18 AM
MaxMini81's Avatar
MaxMini81
Wanderer
I'm pretty sure I was just blamed for this by the Mini techs. Apparantly they don't see many cars as modded as mine. I realize this is St. Louis, but we're talking an air diverter, intake, coil pack, wires, and occ. The rest is purely aesthetic.
Old Oct 8, 2009 | 09:37 AM
stevecars60
Well, St. Louis isn't the Idaho panhandle either. After all St. Louis is the home of some of the best ribb places in the universe.
Old Oct 8, 2009 | 09:43 AM
MaxMini81's Avatar
MaxMini81
Wanderer
$4,500
Old Oct 8, 2009 | 09:53 AM
stevecars60
Get an RMW head & have the best people you know put it on.
If you lived close by I could make the repair for less than $400 & back it up for a year, make it 5 years. I'v never had an insert fail, our shifter kart motors, Bow-Tie aluminum SB heads, Porsche & my own Cosworth Mini head.
Old Oct 8, 2009 | 10:04 AM
Machupo's Avatar
Machupo
Originally Posted by MaxMini81
$4,500
I'd tell them to eat a ****! For that you can get a performance head installed!
Old Oct 8, 2009 | 10:59 AM
jimz68's Avatar
jimz68
$4,500
I want some of that crack they're smoking!!
Typical "parts replacers".
There MUST be an Independent BMW/MINI shop in your area.
Jim
Old Oct 8, 2009 | 11:05 AM
stevecars60
Jim
I want the yact.... but only if it has sails
Old Oct 8, 2009 | 11:07 AM
MaxMini81's Avatar
MaxMini81
Wanderer
It's at least gonna be a JCW head
Old Oct 8, 2009 | 11:14 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Just gathering information here, but did you use anti-seize and proper torque spec when you installed the plugs? Re-torqued them after a few thousand miles?
Old Oct 8, 2009 | 11:45 AM
stevecars60
That's going to cost as much or more than the RMW & not flow even close to what other builders are marketing. It's worth an email to Jan jan@revolutionmini.com or take a look here http://www.thumperheads.com/
Old Oct 8, 2009 | 11:47 AM
MaxMini81's Avatar
MaxMini81
Wanderer
I take pretty good care of my car, and yeah it was all done by the book. For the life of me I can't figure out what happened, but it turns out that a JCW head cost the same as replacing the stock head, and while a RMW it's not, it's better than I had so Ill just have to buck up a deal with it.
Old Oct 8, 2009 | 12:05 PM
mdbsat's Avatar
mdbsat
Smart move
Sorry this happened to your car
Old Oct 8, 2009 | 07:02 PM
Rich.Wolfson's Avatar
Rich.Wolfson
$4,500
Depending on how bad the threads are a KD Back-tap spark plug thread tool may work. I have used it successfully before.
It seems our plugs like it when they are installed in COLD heads at 20-22 Ft/lbs. I check mine every 5000 miles at each oil changed. They have not come loose ever.
Rich
