Drivetrain My custom Stainless Cold Air Intake
Old Sep 29, 2009 | 09:48 AM
  #26
Porthos's Avatar
Porthos
That gives me an idea to fab up the air inlet tube that goes to the bottom of the filter. Make it staighter and a little rounder. Now a performance mod but it would be better air flow.
Old Sep 29, 2009 | 10:42 AM
  #27
kenatminimania's Avatar
kenatminimania
Originally Posted by superc00per
Just a bit of background. I'm a mechanical engineer with a background in fluid /heat transfer. I didn't really like a lot of the intakes on the market since most either sucked hot air, or were made from flimsy materials. So I set out to fabricate my own for the purpose of: 1. Function like the stock setup 2. make a better sound than the stock setup. 3. look good.
This is what I came up with. It is heavy gauge stainless steel (#7 polish) and will allow for use of the stock panel filter, or a K&N cone. Video clips and process photos to follow soon.
[IMG][/IMG]
Nice work!
Old Sep 29, 2009 | 03:15 PM
  #28
eg0911's Avatar
eg0911
3. The 'cold' part that everyone refers to is the fact that the system is sealed, just like factory. It's pulling outside air from the cavity behind the grill and fog light area using the factory 'snorkel'. 'Cold' only refers to sucking ambient outside air, regardless of its temperature. The open filter systems that I've seen, all suck the 'hot' engine air. I've seen estimates that for every 10 degree drop in temp, an engine can gain 1hp. How true that is for out cars, I do not know. I'm not all that concerned either to be honest, but that theory still applies I guess. Air is more dense as it gets colder.
there are more variables than just temperature you know? but its an estimate that seems to be true most of the time. cars with turbos seem to get better gains when it gets cold, you dont loose all of that hp in the terrible stock front mount when its cold. not exactly a gain in horsepower just a retrieval of your lost horsepower due to inefficiency
btw what cad program were you using, and what did you use for the programing of the cnc?
Old Sep 30, 2009 | 04:25 PM
  #29
superc00per's Avatar
superc00per
Solidworks 2010 for CAD. The program is generated directly from the model. Mastercam will work too for milling and machining. Gone are the days of typing in strings of code. At least at our shop.
Old Sep 30, 2009 | 04:41 PM
  #30
drewstermalloy's Avatar
drewstermalloy
Looks good, sounds good!
Old Dec 6, 2009 | 11:27 AM
  #31
AutoXCooper.com's Avatar
AutoXCooper.com
If you like what superc00per made you can now get one at
https://www.northamericanmotoring.co...bo-owners.html
chrisx18240
26
Mar 16, 2022 09:56 AM
W0TM8
Dec 19, 2019 07:50 AM
theblackfalcon
Aug 26, 2015 09:18 AM
rentedblackbird
Aug 24, 2015 10:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
