Drivetrain Supercharger pulley swap
Old Sep 23, 2009 | 11:27 AM
Neufusion's Avatar
Neufusion
I have a friend with a ALTA 15% supercharger pulley that he says I can take if I replace with a stock one.
My understanding is that the stock supercharger pulley is a one time use; you have to toss it if you remove it. Is this true?
Can the ALTA 15% pulley be removed from one car and installed on another?
Old Sep 23, 2009 | 11:54 AM
Eric_Rowland's Avatar
Eric_Rowland
The Alta can definitely be swapped, but re-installing the OEM could be difficult/impossible. In the dawn of the new MINI, the procedure called for heating the pulley in an oven to several hundred degrees so that it would slide on over the supercharger spindle. There is significant risk of not getting the pulley properly aligned.
Old Sep 23, 2009 | 11:59 AM
go_mini_go's Avatar
go_mini_go
+1 I tried to reinstall a stock pulley, got it good and hot, but you almost need to have the supercharger sitting next to your oven. It went about halfway before it started to cool and not budge. You also need to be carefully to get the backspacing correct or it will just eat belts and leave you stranded (or him stranded).
Old Sep 23, 2009 | 04:21 PM
Neufusion's Avatar
Neufusion
Is this true for both new and used OEM pulleys?
Old Sep 23, 2009 | 05:08 PM
go_mini_go's Avatar
go_mini_go
I would think so. It's a tapered fit, I think maybe if you heated it up, got it started, you could draw it on the rest of the way with a bolt in the shaft. Don't know, I'm sure someone has got one back on somewhere!
Old Sep 23, 2009 | 05:15 PM
poskey's Avatar
poskey
If I recall, when I bought my 17% from helix a couple years ago, they offered a stock size pulley. Give them a call.
Old Sep 23, 2009 | 07:04 PM
PinesMini's Avatar
PinesMini
I will trade for Stock Pulley. PM if your interested..
Old Sep 24, 2009 | 02:20 AM
Neufusion's Avatar
Neufusion
Ack... So it seems I'd be better off just buying a new 15% for my car. Half the labor...
Old Sep 24, 2009 | 07:44 AM
Bigshot's Avatar
Bigshot
Can't really use the OEM one again.
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
offroadratfabricator
Sep 6, 2015 09:54 AM
M7Speed
Sep 3, 2015 07:48 AM
