Drivetrain Oil leak at tappet cover
Old Sep 11, 2009 | 06:45 AM
R53's Avatar
R53
I checked out my engine bay and i noticed that there were some oil ontop by the tappet cover, head gasket compartment, just where the headers bolt onto the head. There were some oil located at that area. I wanted to know if this is a common problem? If it isnt then what is the fault and what should be done about it?
Old Sep 11, 2009 | 06:47 AM
R53's Avatar
R53
P.S i do have an aftermarket header
Old Sep 11, 2009 | 07:26 AM
JAB 67's Avatar
JAB 67
My 2004 MCS developed this same problem at about 70K. I'm told it is not uncommon.
Old Sep 11, 2009 | 08:22 AM
jhiggs26's Avatar
jhiggs26
It's simple: RE and RE your valve cover gasket.
Jeremy
Old Sep 11, 2009 | 08:31 AM
R53's Avatar
R53
Explain what RE is please?
Have you experienced this problem?
@ jab 67 - what did you do about the problem?
Old Sep 11, 2009 | 08:40 AM
JAB 67's Avatar
JAB 67
My car was in the shop (independent) for installation of lower control arm bushings when the diagnosis was made. New gasket was installed. Cost around $250 (parts and labor) as I recall. Yes, I probably could have done it myself.
Old Sep 11, 2009 | 08:46 AM
R53's Avatar
R53
So once you replaced the gasket, oil no longer creepd out ontop by the header area where it bolts on?
Is this a serious issue? What if i just leave it?
Old Sep 11, 2009 | 09:49 AM
jhiggs26's Avatar
jhiggs26
R53, I have not experienced this problem. RE and RE=remove and replace.
I changed mine when I did a camshaft RE and RE.
I'll do anybody's valve cover gasket RE and RE for $250!
Jeremy
Old Sep 11, 2009 | 08:21 PM
R53's Avatar
R53
So if i have it replace, the problem woud stop? No oil by header bolts?
Also what can go wrong if i dont replce it now?
Old Sep 11, 2009 | 08:23 PM
R53's Avatar
R53
So if i have it replace, the problem woud stop? No oil ontop by the header bolts area/tappet?
Old Sep 11, 2009 | 09:22 PM
jhiggs26's Avatar
jhiggs26
First I would check the tourque on the valve cover bolts. If a few are not up to spec then that may be the cure. BUT if it were me I'd replace the valve cover gasket.
Jeremy
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
azntaiji
Aug 13, 2015 03:24 PM
