Drivetrain Tap sound after CAI install
Old Sep 2, 2009 | 02:04 PM
Elessar's Avatar
Elessar
After installing my ALTA CAI and turbo inlet tube I now have some great turbo sounds (the reason I went with a CAI) but also now hear a tap sound of metal on metal just after moderate to hard accleration. Has anyone else experienced this? I first thought it might be hitting the hood but have ruled that out. ALTA thought it might be hitting the firewall but I have yet to determine where.
I moved the clamp screw shown in the first picture so that it's not so close to the firewall but still hear the sound.
Attached Thumbnails Tap sound after CAI install-img_0164.jpg   Tap sound after CAI install-img_0160.jpg   Tap sound after CAI install-img_0161.jpg
Old Sep 2, 2009 | 03:08 PM
slinger688's Avatar
slinger688
You can call Alta to see if they can help you.
Old Sep 2, 2009 | 03:16 PM
ALTA_Jarid's Avatar
ALTA_Jarid
OO OOO I have an idea. Put some vaseline along the seal of the airbox on the firewall side and then go for a run....see if it transfers vaseline to the firewall. done!
Old Sep 2, 2009 | 03:26 PM
sonnysu's Avatar
sonnysu
I am sure it is the sound generator, remove it and you will be ok
Old Sep 3, 2009 | 06:53 AM
Elessar's Avatar
Elessar
Have you removed your generator? I was planning on installing an ALTA FMIC this weekend and the hot side tube. What did you use to block off the hose?
Thanks, I'll try that one this evening after work.
Old Sep 3, 2009 | 10:02 AM
sonnysu's Avatar
sonnysu
[quote=Elessar;2863123]Have you removed your generator? I was planning on installing an ALTA FMIC this weekend and the hot side tube. What did you use to block off the hose?
I had the same isue with my alta CAI and Adam from Alta told me about the sound generator, You just need to plug in the cilinder that comes with your CAI, if you dont have it just call Adam, he will send you one.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
David.R53
Sep 1, 2015 06:49 PM
spec35
Aug 18, 2015 07:07 PM
