Drivetrain Help! My car puked oil and I don't know why.
Old Jul 26, 2009 | 09:59 AM
Act_04's Avatar
Act_04
I changed the oil, oil filter, and o-ring 2 weeks ago with no problems. I had driven at least 1000 miles and there were still no problems. I got home after a ~100 mile drive and parked in the driveway, washed my car, left it there for several hours and then went out again. I came home and in the morning there was a puddle of oil under my car. There was also oil slung all along the underside of the car. There was no oil in the driveway of the house I left before I came home the night before, and I did not hit anything on the way home. I drained the oil and there was only 3 quarts left.
The only thing I can think I may have done wrong is over-tighten the oil filter, but with the amount of miles I put on it between the oil change and the oil puking I doubt that's it. I had it at 25 ft/lbs. I traced said puking to the oil filter area, but I'm still not convinced it was caused by over-tightening. The old o-ring at the oil filter was not torn or ripped. The oil filter was Purolater, not MINI.
I have since changed the oil, o-ring, oil filter, and tightened it to 18 ft/lbs (spec). I have driven it three times with no issues.
Does anyone have ideas about what may have happened.
Old Jul 26, 2009 | 10:16 AM
not-so-rednwhitecooper
You didnt change the o-ring? That was probably the issue. That and over tightening the filter housing. You can just snug it, the o-ring does the sealing, not the threads.
Also, use only MINI filters and their o-rings, they are the best and will never give you any problems.
Old Jul 26, 2009 | 03:20 PM
Act_04's Avatar
Act_04
I did change the o-ring both times, and that's been edited above. Sorry for the confusion.
Would 7 ft/lbs really cause it to react like that? and after 1000 miles? Not that I don't believe you, I just want to be "sure".
Old Jul 26, 2009 | 03:37 PM
TRuTH's Avatar
TRuTH
Did you use an OEM filter, I had this same problem using an STP filter and O-ring. Once I went back to the dealer and got a new OEM filter and more importantly a new OEM o-ring the problem stopped. The o-ring that STP supplies you with is too small in diameter and causes a leak.
Old Jul 26, 2009 | 03:46 PM
Act_04's Avatar
Act_04
It was not an OEM filter or o-ring, it was a Purolator. I will order one from the dealer. Thanks for the info.
Old Jul 26, 2009 | 06:16 PM
herbie hind's Avatar
herbie hind
the vendor here called mini carparts sells good filters .at fraction of dealer cost . i buy them like 4 to 6 at a time and never an issue
Old Jul 26, 2009 | 08:36 PM
MrCooperS's Avatar
MrCooperS
Moderator
I'm 100% sure it's your oil filter. When my MINI leaked oil, it goes all over the place and can cause a false diagnoses. I used a STP filter twice in a row and they both caused leaks within 200 miles. It's the damn o-ring on them. Always go OEM.
Old Jul 31, 2009 | 01:53 PM
TRuTH's Avatar
TRuTH
I did the same thing, and when I called customer service to give them my 2 cents they wont even stand by their product. I will NEVER NEVER buy STP products again.
Old Aug 10, 2009 | 02:34 PM
Act_04's Avatar
Act_04
Alright guys, thanks for the help!
I got a factory filter and I haven't had a problem. As far as the factory filters being difficult to install (as I've heard some say), I put a decent amount of oil on the inner ring of the filter where it slides onto the cap. Once it soaked in a bit I was able to press it onto the cap with some firm twisting and pushing. I lubed/soaked the other end the same way so it could slide onto the mount in the engine. This helped me from having trouble with cross threading.
Colt45Magnus
Jul 14, 2019 06:18 PM
silence2-38554
Nov 12, 2015 09:39 AM
ludedude
Aug 10, 2015 07:16 PM
M7Speed
Aug 6, 2015 01:48 PM
