Drivetrain Front disk sagging
Old Jun 23, 2009 | 05:24 PM
P1N HIGH's Avatar
P1N HIGH
Front disk sagging
After taking off my wheels, and front strut, the front disk just sags. Is this normal? It feels way too loose and wobbly.
Old Jun 23, 2009 | 05:59 PM
daemon2's Avatar
daemon2
Normal
What year and mileage on car?
Old Jun 23, 2009 | 06:00 PM
Dr Obnxs's Avatar
Dr Obnxs
yes...
the steering knuckle is held in place by the lower ball joint, the tie rod and the strut. If you disconnect the strut, there's nothing to hold the steering knuckle in place, and the whole thing will drop down as the front control arm moves down. You should be supporting it so it doesn't drop too far, and (at least on the earlier cars) it could flop such that the half-shaft could come out of the tranny.... I don't know if this is an issue with the newer version though.
Matt
Old Jun 23, 2009 | 06:25 PM
P1N HIGH's Avatar
P1N HIGH
It's a 2009 Mini.
It feels like the half shaft did come out of the tranny.
The only time I had this feeling was in my BMW when the shaft came out. What a nightmare that was.
Old Jun 23, 2009 | 06:30 PM
Oxybluecoop's Avatar
Oxybluecoop
Matt
Yeah it's still possible to pull the half shaft out if you let the knuckle drop too far.
Old Jun 23, 2009 | 06:59 PM
lhoboy's Avatar
lhoboy
Don't do that. You need to support it.
Old Jun 23, 2009 | 07:23 PM
P1N HIGH's Avatar
P1N HIGH
Great so what am I to do if my shaft is out?
Old Jun 23, 2009 | 07:30 PM
Oxybluecoop
post a few good pics of it and I'll tell you if its out
Old Jun 23, 2009 | 07:32 PM
P1N HIGH's Avatar
P1N HIGH
Hey OXYBLUE, if it is out though what do you recommend? I mean the car is under warranty and all. Only has 850 miles on it.
By the way nice cars! I am looking forward to getting a Cayman S in the future myself.
Old Jun 23, 2009 | 07:40 PM
Oxybluecoop
The collar pin that holds the CV boot is pretty strong and should hold the shaft from falling out so unless you put lot's of pressure on it while it was hanging(which is easy to do on the passenger side since that struts a PIA to get out) it hasn't come out.
Old Jun 23, 2009 | 07:44 PM
P1N HIGH's Avatar
P1N HIGH
Oh, the side that is hanging is the drivers side. I was told to just give some elbow grease to get the strut out so I did such and then bam! The dam thing just gave up and now the brake disk is at a 45 degree angle.
So what are some tests I can run to verify that it hasn't fallen out? I would love to get some pics of it, but I don't think my condo will like me working on my car at this time. It's almost 11pm where I am now.
Old Jun 23, 2009 | 07:52 PM
Oxybluecoop
Assuming you have the whole front end up put something under the elbow and turn the other wheel. Both should turn.If the strut is out it's gonna hang.
Old Jun 23, 2009 | 08:04 PM
Oxybluecoop
Alright I just checked with the TIS and 45 degrees is what the wheel side joint should be. In other words just hook everything back up and you should be fine.
Old Jun 23, 2009 | 08:21 PM
P1N HIGH's Avatar
P1N HIGH
OXY Thank you! I really appreciate all your help. Next I am in DC, drinks on me.
Old Jun 24, 2009 | 08:19 AM
Dr Obnxs's Avatar
Dr Obnxs
Sorry can't resist...
Should have learned the lesson the first time! Anyway, if you have to do this in the future, get the car on stands and use the jack to support the knuckle...... I find this works well....
Matt
Mini7
Feb 2, 2016 07:52 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
