Drivetrain Revolution MINI Works (Jan) Tune Event - Limerock, CT
Old Jun 5, 2009 | 05:13 AM
  #176
killerfox's Avatar
killerfox
Originally Posted by MiniPOLACK
Steve..im kind of pissed off about the boost levels set. Why are you running 17.5 and im only getting 15psi? thats not fair!!! at first i thought i was running like 16-16.5 , but i guess car was just in the stage of getting acquinted with the new software. no its constant 14-15 ONLY!!!! i smell conspiracy from Jans side to keep all the minis tune on same HP LEVEL :(
I remember Jan saying you couldn't run as much boost as the other cars because of your intercooler. Not sure why but that's what I remember him saying, unless I misunderstood
Old Jun 5, 2009 | 07:28 AM
  #177
dtsoccer6's Avatar
dtsoccer6
I highly doubt any conspiracy and Dave is right. Your IC, although very large in diameter is very thin. Also remember, temperature change and climate temps will have a greater impact on your car because its so thin.
I haven't really pushed the car wot recently and I'm getting about 15 to 16 psi. Maybe Tyrolsport can make an IC large like the one you have, but make a thicker core. I'm not sure the reason exactly, and someone correct me if I'm wrong, but my numbers havent dropped dramatically like that, which would lead me to believe its not the RMW Tune.
Old Jun 5, 2009 | 10:19 AM
  #178
MiniPOLACK's Avatar
MiniPOLACK
I remeber Jan saying something about the intercooler , but I kept quiet because we didn't tested it yet under high boost. Now that we tested the unit with 5 back to back runs with nominally 0 hp/tq loss I do t understand why he couldn't go higher in psi . Our core is thin for a reason to release heat while driving, quicker than thicker cores.
Here's a quick update : with my setup we decided to experiment how the stock intercooler would handle against high boost. By simply swapping back to stock intercooler and relatively cold engine , we lost 30whp/20wtq. And when we did 4 back to back runs we kept on loosing more where max came out to be 38whp/26wtq loss.
Old Jun 5, 2009 | 11:25 AM
  #179
dtsoccer6's Avatar
dtsoccer6
Jan said the VVT maps (Vanos) will not be ready for the local tunes in NY and PA. Oh well, I guess we will wait for the flash tool.
Old Jun 5, 2009 | 02:47 PM
  #180
orangecrush's Avatar
orangecrush
So are you saying that a bigger intercooler will result in lower numbers?
Thanks,
Mark
Old Jun 5, 2009 | 04:06 PM
  #181
killerfox's Avatar
killerfox
Thanks,
Mark
I think what was happening was on the dyno because of the thinner walls of the intercooler on his car, it was getting heatsoaked faster. Just a guess as to what might have happened. I believe Jan would only increase boost as long as the intercooler could handle it. Just my opinion on what I saw, only Jan can say for sure why he limited the boost on that car.
Old Jun 5, 2009 | 04:20 PM
  #182
orangecrush
Why, is Alta's intercooler's walls thinner than most? I installed a Forge intercooler just for Jan's tune. I hope it does what it's suppose to.
Mark
Old Jun 5, 2009 | 04:27 PM
  #183
killerfox's Avatar
killerfox
NO, MiniPolack's intercooler is as big as a radiator but very thin as compared to Alta's or Forge.
Old Jun 5, 2009 | 06:31 PM
  #184
dtsoccer6's Avatar
dtsoccer6
Yeah, the thinness is the only down side to his IC. Thing is massive though
Old Jun 5, 2009 | 08:45 PM
  #185
mistro's Avatar
mistro
waiting to see my video.... the 249.4 hp gen 1 MCSC!
Old Jun 5, 2009 | 10:31 PM
  #186
old81's Avatar
old81
M6
Originally Posted by MotorMouth
Is that from a scanguage?
would you post a pic of it sorted by engine speed?
graphing it would be really cool too.
No, this is from Rev. (DevToaster) on the iphone/itouch with the data coming from a Plex wifi.
I can sort by RPM. I really need to do a longer run, this was a short sample running up Hwy 42 which is not the best place to data log.
I'm working on some graphing in excel, we shall see how it all goes. Lots of data gets sampled.
Don
Old Jun 6, 2009 | 03:24 PM
  #187
dtsoccer6's Avatar
dtsoccer6
Working on it!!
Old Jun 8, 2009 | 07:54 AM
  #188
dtsoccer6's Avatar
dtsoccer6
Don
Can you elaborate on the part about the iphone? That sounds interesting. Looking forward to seeing what you come up with.
Both you and Christophe will have vids up by tonight, latest tomorrow morning!
Old Jun 9, 2009 | 01:19 PM
  #189
FrenchyR53's Avatar
FrenchyR53
Thank you Steve..looking forward to it!
Old Jun 19, 2009 | 05:52 PM
  #190
second to none's Avatar
second to none
I think this is a misunderstanding. Any intercooler will absorb a specific amount of heat over a period of time based upon it's mass. If you have a thin, tall intercooler, and a smaller yet thick intercooler of the same weight (same amount of material), they will theoretically absorb and dissipate an equal amount of heat.
Introduce air flow. The TyrolSport intercooler uses a taller core to take advantage of two airstreams. One uses the lower half of the grille in the bumper, and the second uses air from the upper grille. A comparable intercooler may have an equal mass, but the effect on the rate at which it cools the intake charge will be different.
Wohnson89
Jun 10, 2020 04:53 AM
sungjk
Aug 5, 2015 08:23 PM
Llanrhaeadr_Cymru
Country Roads MINIs
Aug 5, 2015 02:58 PM
