Drivetrain GT2560R Turbo kit
Old May 25, 2009 | 05:30 PM
  #26
chakraj's Avatar
chakraj
where did you put the pump and reservoir for your water meth system? it looks like you have a tube coming from the rear of the car?
Old May 25, 2009 | 06:45 PM
  #27
Oxybluecoop's Avatar
Oxybluecoop
Probably the wiper fluid reservoir since it has a pump with a low level indicator on the tach.
Old May 26, 2009 | 12:17 AM
  #28
XaLia's Avatar
XaLia
Thats right..I put there because its very easy for installation and you can see when the level of water meth is low..
The pump is hidden to the compartment next to the battery..
My pump is smaller than yours and it fitted perfectly..
Old May 26, 2009 | 12:23 AM
  #29
XaLia's Avatar
XaLia
Did you injected any water/meth??
You saw any difference??
Old May 26, 2009 | 08:35 AM
  #30
chakraj's Avatar
chakraj
I am having a hard time adjusting it properly. I should have it done soon.
Old May 28, 2009 | 07:23 PM
  #31
ThumperMCS's Avatar
ThumperMCS
Old May 29, 2009 | 08:49 AM
  #32
chakraj's Avatar
chakraj
Its working great. I was having a hard time because the instructions where a little off. Now that I have it figured out, thanks to Jeff, and Chris at Alta. It is great. On my stock ecu map, I can still notice an improvement. The difference is before it would start to run out of steam a little over 5k rpm (as we all know) Now the water\meth kicks in around 3500 or 4000 rpm and there is no more power loss, it seems to continue to give good power all the way to redline. Infact it has a little jump or boost when it kicks in, it just feals stronger with the water\meth flowing. not like nitro but a little.
Still no real dyno results... But now when I do get a tune oh, ya
Old Dec 2, 2009 | 04:56 AM
  #33
XaLia's Avatar
XaLia
After a long time using the unichip with my turbo kit i decided on going on a different Ecu reprograming.
I am glad i did it..
The results are 295 bhp..
Old Dec 2, 2009 | 09:15 AM
  #34
skippydog's Avatar
skippydog
Nice Numbers! The other guys on a diff post are trying to say that the conversion isnt the best bang for the dollar. Looks like you just proved my argument that it is!
Old Dec 2, 2009 | 11:59 AM
  #35
eg0911's Avatar
eg0911
very nice, now only if a us spec mini can hit that number!
Old Dec 2, 2009 | 12:52 PM
  #36
skippydog's Avatar
skippydog
It will hit that number here in the U.S. We just need someone with mod to show up to one of the local tuners and start hacking out what needs to be done.
Old Dec 2, 2009 | 01:13 PM
  #37
ThumperMCS's Avatar
ThumperMCS
very soon my friend....very soon
Old Dec 2, 2009 | 03:12 PM
  #38
mariomllr's Avatar
mariomllr
215kw thats 220whp!!!! i was doing 265whp with the tuned unichip
Old Dec 2, 2009 | 03:59 PM
  #39
skippydog's Avatar
skippydog
215kw is roughly 292bhp
at 20% drivetrian loss that would be 233.6whp.
What is our average drivetrain loss? Is it 11% roughly?
11% drivetrane loss would be 259.88whp
Mariomllr that is very close to what you are doing you have to take into consideration the dyno used and the conditions. Temp elevation ect. Slight differences in the car and the tune.
Old Dec 2, 2009 | 05:39 PM
  #40
mariomllr's Avatar
mariomllr
loss
18 %front wheel drive 26%all wheel drive
Old Dec 2, 2009 | 05:45 PM
  #41
ThumperMCS's Avatar
ThumperMCS
That was done on a Maha dyno....
They operate a little bit differently than you typical dyno, but are known to be VERY accurate. They are also crazy expensive...it is the same dyno that most of the European car manufacturer's use at their testing facilities.
After the run, it will calculate drivetrain loss over the entire rev range, as the rollers slow the cars wheels down. That's what that straight green line is at the bottom...a plot of the drivetrain loss in horsepower. Drivetrain loss is not a static value across the entire rev range...it increases as RPM increases, and varies from one car to another car. Saying "this car has an 11% drivetrain loss" doesn't really mean a whole lot of anything.
Old Dec 2, 2009 | 05:46 PM
  #42
mariomllr's Avatar
mariomllr
i was making 265 whp (312 crank bhp)and 275 wheel torque(324.5 crank torque) ,kw is wheel hp!!!!! your bhp is 253.7 and i was runing only 15psi
Old Dec 2, 2009 | 05:54 PM
  #43
ThumperMCS's Avatar
ThumperMCS
kW is not wheel horsepower....its just a different unit of measurement of measuring power.
On this dyno sheet, there is no wheel horsepower. The blue line says it is, but it isn't....there are 2 ways to run the car on a Maha that will either produce crank horsepower or just wheel horsepower. This was done to show crank horsepower only.
Old Dec 2, 2009 | 06:48 PM
  #44
skippydog's Avatar
skippydog
So what are the actual numbers here? 18% really dang! I knew its not static and it also has to do with other factors. Is that with the stock runflats and rims?
mariomllr,
Are you stateside? Do you have a dyno graph we can take a look at also? The 28rs is the setup I am looking to get.
Old Dec 2, 2009 | 09:08 PM
  #45
XaLia's Avatar
XaLia
Dont forget that i am running a gt2560r and you
a gt28rs which is a little bit bigger than mine
a maha dyno has lot of differences than the dynos in US
the most important thing is how the car is running and its quite fast!!
I am glad that you pulled those numbers but i dont believe that unichip
is perfect for big turbos!!
Old Dec 2, 2009 | 11:19 PM
  #46
Ottoman_FD3S's Avatar
Ottoman_FD3S
Xalia,
Great car and numbers bro
what ecu software do reccomend for us euro mini's to use?
Old Dec 3, 2009 | 07:51 AM
  #47
XaLia's Avatar
XaLia
There are many ecu softwares recommended for a tuned mini
with an oem turbocharger!!
If you have installed a turbo kit then i believe that you search a lot to find
a good tuner!!
Mine is a greek tuner who managed to reprogram my mini
in 3 hours!!
One on the road and two on the dyno!!
Old Dec 8, 2009 | 10:14 AM
  #48
unit13's Avatar
unit13
I am still holding out for the unichip to come through. they are making a dedicated website for the mini tuners as they have done for other cars so hopefully when we can put our heads together we will come up with higher numbers. I am sure they should be better because I had 220whp before the bigger turbo and even untuned at 14psi the bigger turbo was burning off the tires right through second.
Old Dec 8, 2009 | 09:30 PM
  #49
dunphyj's Avatar
dunphyj
Old Jan 26, 2010 | 03:40 PM
  #50
JamesHunt's Avatar
JamesHunt
