Drivetrain Alta tensioner stop noise?
Old Apr 1, 2009 | 12:10 AM
M3NTAL's Avatar
M3NTAL
Users of the Alta Tensioner stop - could you tell me how loud or noticeable it is for a daily driver?
Old Apr 1, 2009 | 07:11 AM
idickers's Avatar
idickers
No noise whatsoever in our daily driver. I had heard of rattles when perusing this board, but haven't noticed any yet. I could see rattling starting up if the bolt works loose, or if the slot in the tensioner stop does not engage fully.
Ian
'02 MCS (with no tensioner rattles)
Old Apr 1, 2009 | 07:16 AM
Bigshot's Avatar
Bigshot
No problems heard here.
Old Apr 1, 2009 | 07:45 AM
M3NTAL's Avatar
M3NTAL
Cool, thank you guys!
Old Apr 2, 2009 | 01:21 AM
Mike S's Avatar
Mike S
I have a slight rattle on idle and near redline, but not major enough to bother me.
Old Apr 24, 2009 | 06:06 PM
socerguy2110's Avatar
socerguy2110
I also had a slight rattle at idle. A quick fix is take off the front passenger wheel and wheel well, unscrew and rotate the tensioner, wrap the sides opposite of the screw with duck tape (only the area that can touch metal). With that the rattle will turned into a purr. Hope it helps.
Old Apr 26, 2009 | 07:22 PM
apexer's Avatar
apexer
I didn't like the Alta stop. After couple thousand miles started to rattle like crazy at idle. Tried several things to fix including grease the slot... liquid rubber, etc.
Finally, replaced it with Detroit Tuned stop. That was over 8K miles ago and no noise/rattle.
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Hippiehobbit267
Sep 1, 2015 06:13 PM
12magnum
Aug 31, 2015 08:22 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
