Drivetrain Check it out
Old Mar 24, 2009 | 12:25 PM
mtuning3's Avatar
mtuning3
Check it out
check this out the stock pipe is about 1.45 inch in diameter where its crimped now its 2.25 all the way to the intercooler i cant believe no body came out with this yethttp://s627.photobucket.com/albums/tt360/mtuning3"]http://s627.photobucket.com/albums/tt360/mtuning3"]http://s627.photobucket.com/albums/tt360/mtuning3[/URL][/URL]
Old Mar 24, 2009 | 01:35 PM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
Originally Posted by mtuning3
check this out the stock pipe is about 1.45 inch in diameter where its crimped now its 2.25 all the way to the intercooler i cant believe no body came out with this yethttp://s627.photobucket.com/albums/tt360/mtuning3"]http://s627.photobucket.com/albums/tt360/mtuning3"]http://s627.photobucket.com/albums/tt360/mtuning3[/url][/url]
I looked into it, however you cant do it because there is no space. I placed a 2.25" piece of tubing there and the hood would not close.
Old Mar 24, 2009 | 01:45 PM
mtuning3's Avatar
mtuning3
well i got it done and its a perfect fit
Old Mar 24, 2009 | 01:56 PM
Exhaust Depot
What size tubing you use? Is there enough space where the stock one is at, as far as hidden space that you cant see unless you remove it? Thats teh worst pipe on the whole system!
AH i see what you did. YOu made the one piece by the sensor. The oem one is one full piece but I dont think its possible to make one as long as the oem piece.
Good job by the way!
Old Mar 24, 2009 | 02:33 PM
Bigjoeski08's Avatar
Bigjoeski08
I wonder if it add's more gain already to the other tube replacement's.
Old Mar 24, 2009 | 02:40 PM
mtuning3's Avatar
mtuning3
well the turbo spools up 400 rpm faster to full boost and faster turbo response less lag,and the car pulls stronger
Old Mar 24, 2009 | 02:41 PM
Exhaust Depot
I can really see that happening! Also im sure the boost would go up too if it was not for the ecu over controlling it.
Old Mar 24, 2009 | 03:01 PM
Bigjoeski08
Ok so who is going to step up to the plate and mass produce this?
Old Mar 24, 2009 | 03:16 PM
richi0207's Avatar
richi0207
I've always asked myself why nobody offered tubing for this part, I did not want to try to make one because of that sensor there.
Old Mar 24, 2009 | 03:45 PM
mtuning3's Avatar
mtuning3
its a verry tight fit you have to oval shape the 2.25 inch tubing took me 3 hours to make it but its worth it realy change the car drivability and i dont think alta boost pipes make any differance if you dont do that piece because there is a lot off restriction in that pipe,specialy im doing bigger turbo so i needed to change that pipe,the car is going tomorow for tuning,i cant wait
Old Mar 24, 2009 | 03:51 PM
Exhaust Depot
Bring your ride down, its in the 80's in orlando and we can to water sking.
Old Mar 24, 2009 | 03:59 PM
got.pho?'s Avatar
got.pho?
just make some more of them and im sure ppl will ''donate'' to your cause
Old Mar 24, 2009 | 04:06 PM
a96bimmerm3's Avatar
a96bimmerm3
How was this logged?
Old Mar 24, 2009 | 04:17 PM
chakraj's Avatar
chakraj
a few questions, is the red pipe just a bent pipe or does it have a place for the sensor to plug in?
Also what are you connecting the bottom of the red pipe to? did you just cut the existing pipe before the bend? or are you using something else?
Old Mar 24, 2009 | 04:26 PM
mtuning3's Avatar
mtuning3
i have a data logger and i can see my boost gaugeyes the boost pipe is bent and i welded a nipple on it
Old Mar 24, 2009 | 04:29 PM
chakraj's Avatar
chakraj
where did you get the parts? and can you give a list of what you did so someone can copy? or do you want to make another and sell it?
Old Mar 24, 2009 | 04:35 PM
mtuning3's Avatar
mtuning3
i m going to put a kit together and try to make it as cheap as i can
ThumperMCS's Avatar
ThumperMCS
With his A$$ dyno
**edit...just saw he said he has a data logger/boost gauge lol
Old Mar 24, 2009 | 08:57 PM
PoktRokt's Avatar
PoktRokt
count me in on the group buy
Old Mar 24, 2009 | 09:34 PM
dtsoccer6's Avatar
dtsoccer6
me too!
Old Mar 24, 2009 | 11:16 PM
PoktRokt's Avatar
PoktRokt
I've been looking at your design and this piece. Did you try or consider cutting a 8 to 12" piece out the the OEM plastic tube and then connecting the two in the middle with a rubber hose and two hose clamps cinched tight?? That way you could leave the sensor in tact and the rubber hose should be able to make the bend and the inside diameter should be about the same.
Also, did you make the intake scoop/diverter yourself?
Old Mar 25, 2009 | 12:25 AM
Porthos's Avatar
Porthos
Do you have any before and after pictures? Also any during install pictures?
Old Mar 25, 2009 | 03:16 AM
coopman7's Avatar
coopman7
For someone who signed up this month you are making alot of posts about this that and the next thing and all this logging your doing, does it involve a chainsaw because if so then i have 400bhp from the standard K03 turbo and i 'logged' everything to prove it. I am cool, nuff said, end of.
Old Mar 25, 2009 | 03:18 AM
coopman7's Avatar
coopman7
Originally Posted by ThumperMCS
With his A$$ dyno
Well atleast its entertaining. Im amazed people are trying to get in on a buy for something they havent seen, nor have they seen any data, and no clue as to where this guy comes from
Im amazed at the recent influx of posts from people claiming to know all but only just joined... Keep them coming.
Old Mar 25, 2009 | 04:22 AM
mtuning3's Avatar
mtuning3
yes i made the scoop too
