Drivetrain Check it out
Old Mar 25, 2009 | 05:51 AM
  #26
a96bimmerm3's Avatar
a96bimmerm3
Originally Posted by mtuning3
yes i made the scoop too
What'd you use for datalogging? I've been trying to find a good setup.
Old Mar 25, 2009 | 08:04 AM
  #27
mtuning3's Avatar
mtuning3
obdcom
Old Mar 25, 2009 | 08:07 AM
  #28
JAceMin's Avatar
JAceMin
This is how I data log:
software:
http://www.palmerperformance.com/pro...2534/index.php
hardware:
http://www.tactrix.com/product_info.php?products_id=49
Will set you back about $300, but you can talk OBD to just about everything... datalog, read, reset CEL's, even gives road dyno.
There is also open source tools referenced on the tactrix page.
If you need any help setting up, or working with any that stuff let me know, been using it for a few years now.
Old Mar 25, 2009 | 03:22 PM
  #29
richi0207's Avatar
richi0207
Yea, those things are pretty cool in reading data. I borrowed my brother's scantool to reset CEL I had gotten from a boost leak. It displays everything about the engine, its very handy. This is the one I used also.http://http://obddiagnostics.com/
Back to the topic!! You made everything yourself? I see it says Alta on it though.
Old Apr 9, 2009 | 09:41 PM
  #30
PoktRokt's Avatar
PoktRokt
so what became of this idea? Why isn't alta and other companies making this tube to help eleminate the rather aggresive bend in the plastic piping? It seems it could be a major contriction, especially after all the money put into the other boost tubes and bigger FMIC's, etc.
Old Apr 10, 2009 | 05:25 AM
  #31
dtsoccer6's Avatar
dtsoccer6
I agree, someone should make this...one plumbing adjustment may not be a big performance boost, but all the plumbing being changed to unrestricted bigger pipes...thats a different story
Old Apr 10, 2009 | 07:30 PM
  #32
mtuning3's Avatar
mtuning3
the major problem when you change all thoes pipes and make them bigger is lag ,your low end will suffer in torque the turbo need to work harder to full up thoes bigger pipes,but you will get more mid range and hi end power,now a bigger turbo of course it no issue you want them bigger
Old Apr 10, 2009 | 08:03 PM
  #33
gnatster's Avatar
gnatster
Umm...how many threads does this project need?
Can we keep it all in one place please and not have bits of it blown about the forums.
Old Apr 10, 2009 | 08:23 PM
  #34
ThumperMCS's Avatar
ThumperMCS
Amen!
Old Apr 10, 2009 | 08:31 PM
  #35
PoktRokt's Avatar
PoktRokt
I didn't think the aftermarket boost tubes were that much bigger than OEM, just smoother and with less goofy resinator parts etc. IF it is like that though, won't a tune be able to increase boost to "fill up" the bigger tubes.
Old Apr 10, 2009 | 11:46 PM
  #36
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
I did not make the pipes bigger than stock. What I did was to change from rubber to metal. BY doing this your boost actually goes up because the rubber hoses swell up causing you to loose boost. On the neon by replacing 2 pieces of pipe 12" long that are rubber I picked up 1.5PSi. On the mini the ecu might correct and adjust to lower the boost though. REgardless the tturbo will not work as hard and your lag will go down and the throttle will be chrisper.
Old Apr 11, 2009 | 02:10 AM
  #37
coopman7's Avatar
coopman7
Old Apr 11, 2009 | 03:56 AM
  #38
mtuning3's Avatar
mtuning3
i didnt say they were bigger! but by removing all the lumps on them that make them bigger? its all about velocity
Old Apr 11, 2009 | 07:38 AM
  #39
a96bimmerm3
No, its about volume. Restriction= more velocity and less flow, but more torque. It most definitely is not about velocity.
Can you please post your datalogs or SOMETHING factual? If you had ONE post (other than the not full throttle dynos with no air/fuel) that contained some USEFUL data, it would make your postwhoring nearly worthwhile. C'mon man, 4+ threads and no real data? A message board is for spreading information, not claiming to do things yourself (like when you said you make the silicone couplers and aluminum tubing yourself, didn't provide a source). How about the hood cut that theres no picture of? You keep saying things and not backing them up. Please provide DATA to people. Is that so much to ask?
Old Apr 11, 2009 | 10:53 AM
  #40
mtuning3's Avatar
mtuning3
thats what i ment to say
Old Apr 11, 2009 | 10:58 AM
  #41
MiniBAH's Avatar
MiniBAH
As Peter Griffin would say.. "You're priceless!"
lweaver
Sep 17, 2024 08:22 AM
CardinalsRule
Jun 11, 2016 04:34 PM
mimaal
Sep 4, 2015 09:09 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
