Drivetrain Discovered a good tool for the MINI
Old Mar 23, 2009 | 11:01 AM
mtuning3's Avatar
mtuning3
obdcom works great for the latest mini finaly now i know why the engine is cut off in power at 5000rpm the tps shuts down to 44% its ****ing rediculus,the most the tps is open is 76% its never 100% open and by the way the alta intake works greate the most differance i see is 4 degrees higher than outside tempits a very good software you can put gauge on your laptop,even comes with a horsepower calculation.
Old Mar 23, 2009 | 11:32 AM
ThumperMCS's Avatar
ThumperMCS
TPS = Throttle Position Sensor right?
Old Mar 23, 2009 | 11:52 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Is that with or without the sport button on?
Old Mar 23, 2009 | 12:47 PM
mtuning3's Avatar
mtuning3
with it on yes,and yes trottle position
Old Mar 23, 2009 | 01:02 PM
JAceMin's Avatar
JAceMin
sp check is all of our friends
Old Mar 23, 2009 | 05:29 PM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
All these fly-by wire cars are setup gay like that with a 80% or so full throttle opening. That really sux!
Old Mar 23, 2009 | 06:08 PM
richi0207's Avatar
richi0207
Hmm, so how would we get around that?
Old Mar 23, 2009 | 06:20 PM
mtuning3's Avatar
mtuning3
remaping the tps to open 100% thru the ecu
Old Mar 23, 2009 | 06:35 PM
fernflex's Avatar
fernflex
Who can remap this?
Can Mini service do it ?
Old Mar 23, 2009 | 08:57 PM
pillar's Avatar
pillar
explain
Old Mar 23, 2009 | 09:11 PM
SlowB00st's Avatar
SlowB00st
OBD tools/scanner will normally not show 0-100% scale on TPS so its probably opening to 100% as it should. its more like a 15-85% (Just random number it actually depends on the car)
Old Mar 26, 2009 | 06:50 AM
unclemeat's Avatar
unclemeat
Can we pull something off to visually check how open the butterfly<s> are at WOT while the engine is not running?
andrewjg1994
Jan 29, 2021 07:45 PM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
cub4bearindiana
Aug 25, 2015 06:49 PM
kpl
Aug 11, 2015 04:52 AM
pyrrhusmj
Aug 6, 2015 07:42 AM
