Drivetrain Anyone make a pillar mount boost/pressure guage?
Old Nov 21, 2005 | 11:59 AM
  #26
doomsdaybob's Avatar
doomsdaybob
I've seen the pics in the "MINI vs. Mountain" thread and still think pillar mounts are doable. Maybe someone could make them "race only", I'd sign that waiver!
  #27
maxmini's Avatar
maxmini
I helped Pro mini design their Nav equipped pod way back in the day. It works perfectly and looks almost " stock. Get in touch and see if they currently stock them.
Randy
m7 tuning
Attached Thumbnails Anyone make a pillar mount boost/pressure guage?-124-2463_imgnam.jpg
Old Nov 21, 2005 | 12:04 PM
  #28
dominicminicoopers's Avatar
dominicminicoopers
Randy
m7 tuning
So you think this would be wide enough to fit around the Alta guage pod? Do these get hidden by the steeringwheel when the driver is positioned in the driver's seat?
Old Nov 21, 2005 | 12:08 PM
  #29
MSFITOY's Avatar
MSFITOY
Or DIY:smile:
Old Nov 21, 2005 | 12:13 PM
  #30
maxmini's Avatar
maxmini
I can read both gages from the driving posistion. They are just inside the rim of the wheel.
Randy
m7 Tuning
Old Nov 21, 2005 | 01:37 PM
  #31
Bahamabart's Avatar
Bahamabart
why not just cut the promini bracket down the middle - attach one half to the tach and the other half to the speedo?
should give you the effect you are seeking.
Old Nov 21, 2005 | 01:44 PM
  #32
MSFITOY's Avatar
MSFITOY
That's what I thought but I didn't like cutting up a $300 piece so I did the same with $20 worth of aluminum and two Autometer cups
Old Nov 22, 2005 | 01:39 AM
  #33
Tit's Avatar
Tit
or you could put the guages in the vents either side of the speedo....however, I find the closest one to the driver is obscured by the steering wheel, but the far one is good - you could even mount it inside a vent so you can swivel it...
Old Nov 22, 2005 | 04:07 AM
  #34
dominicminicoopers
Yep, I've seen this done. Hubie's done that with his car. Unfortunately, these are not in the line of sight.
I have two guages I want to keep a close eye on without losing my vision on the road.
Old Nov 22, 2005 | 04:50 AM
  #35
Tit's Avatar
Tit
check this out!
http://www.defi-shop.com/product/con...ncept_top.html
I realise it may not include the guages you are interested in, but man - isn't that cool! Funny how it's a technology that's decades old, but it's still not prominent..
I think Nissan tried it with some of it's cars in the 90's....
Old Nov 22, 2005 | 05:13 AM
  #36
dominicminicoopers
Thanks for the link. That's awesome!!
I'm not sure why you think this doesn't have the gauges I'm interested in. It has even more than I'm interested in:
  • Exh T
  • Water T
  • Oil T
  • Oil P
  • Fuel P
  • RPM
  • speed
Old Nov 22, 2005 | 05:33 AM
  #37
Tit's Avatar
Tit
  • Exh T
  • Water T
  • Oil T
  • Oil P
  • Fuel P
  • RPM
  • speed
Well then...perhaps it was a help...
I'm struggling to find some back-lit gauges like the oem ones...ie. silver face, orange back lit.....have you seen any anywhere?
Old Nov 22, 2005 | 05:58 AM
  #38
norm03s's Avatar
norm03s
Adding gauges
Sure, Autometer ultra lite's look almost like OEM.
Tit, my brothers Vette has a HUD, we did a long road trip/caravan for the 50th Corvette Anniversary very nice to the drive by day or night. Afraid it would be very expensive to duplicate in a MINI.
I have three more gauges to install water temp., oil temp.,oil pressure. I pretty much have ruled out the A pillar due to safety concerns.
I acquired a 3 gauge swivel & tilt mount that needs some paint to match. Looks like the top of the dash will be the location.
Who has a how to for removing the dash cover???.
Old Nov 22, 2005 | 06:32 AM
  #39
omascow's Avatar
omascow
I found this from a post by Minionrails. Hope that helps!
Old Nov 22, 2005 | 08:29 AM
  #40
norm03s's Avatar
norm03s
That's from an old post, he fabricated it as a one off I think, to bad they are not available I would reconsider the A pillar.
He must have access to vacuum forming equipment. Once the mold is made you can bang them out for pennies a piece.
All those generic ones you see for like $30.- $12. only cost cents to make
Hey vendors, here is your opportunity to bring a needed part to market.
Old Nov 22, 2005 | 08:50 AM
  #41
Tit's Avatar
Tit
Wow...that is very neat...
I couldn't find a pic of the mini I saw with the guages in the middle of the dash. It's this car from Melbourne, Australia, but I can't find any inside piccies:
Old Nov 23, 2005 | 04:39 AM
  #42
omascow's Avatar
omascow
I figured that it was a custom job but maybe it will get someone's creative juices flowing.
Old Nov 23, 2005 | 05:36 PM
  #43
dominicminicoopers
Minionrails has a neat idea. I went and found his thread and he said he made it from bondo, fiberglass, and an A-Pillar cover.
Old Nov 23, 2005 | 06:13 PM
  #44
MINICHEF's Avatar
MINICHEF
CHECK OUT www.MINISPEED.CO.UK THEY HAVE A-PILLAR PODS FOR MINIS.
I TOO HAVE THE PROBLEM OF ADDING GAUGES TO A NAV CAR.
PROMINIS NEW CATALOG LISTS THIER GAUGE POD FOR UP TO 06 MINIS W/NAV. MIGHT GO THAT DIRECTION AS IT IS ALS A PLUG AND PLAY.
Old Nov 24, 2005 | 06:39 AM
  #45
Bahamabart's Avatar
Bahamabart
While only a single pod, I bought an autometer extended bracket for under 10 bucks modified it to fit my tach pod. Since the bracket was autometer it was designed to accept the autometer cup. This whole set-up was somewhere between 70-80 bucks - bracket, cup and guage. What I really like about it that I was able to determine exactly where the guage appeared - I chose the 8 o'clock position. I used a single screw and a piece of double stick tape to hold it in place so I can change it.
I think it looks pretty good too.
[img]file:///C:/DOCUME%7E1/BCORRE%7E1.TRA/LOCALS%7E1/TEMP/moz-screenshot.jpg[/img]
Old Nov 25, 2005 | 08:41 AM
  #46
norm03s's Avatar
norm03s
A-pillar cover
Could someone help out and describe how to remove the A-pillar cover???
Old Nov 25, 2005 | 08:46 AM
  #47
MSFITOY's Avatar
MSFITOY
Fasten seat belt, drive into inmovable object:smile: Sorry...couldn't resist
Old Nov 25, 2005 | 09:44 AM
  #48
dominicminicoopers
The problem in the USA, is that only the passenger will be getting a good look at the gauges!
http://www.minispeed.co.uk/new_mini/...duct&id=mrb164
Old Nov 25, 2005 | 11:13 AM
  #49
norm03s's Avatar
norm03s
That's $43.99 USD before shipping. I'll pass on the crash method.
Okay, anybody removed an A-pillar cover? How did you do it.?
Old Nov 25, 2005 | 11:17 AM
  #50
not-so-rednwhitecooper
remove waetherstripping.
pry the cover up, its got 4 clips holding it on.
pull away from the actual a pillar, then cut the retaining straps.
i assume your going to be putting a gauge there.
there is a nice space to fish your wires and nylon line up thru near the base of the a pillar, you cant miss it.
and theres a grey/red wire right near there that will assist in lighting up your gauge.
