Drivetrain Question about injector
Old Feb 3, 2009 | 09:49 AM
csnorbi's Avatar
csnorbi
Hi,
i would like to know the original fuel pressure of the Cooper S. (bar???) The original Siemens or Bosch number of the injector. Are these low impedance (2-5 ohm) or high impedance (12-15ohm)??
Has anyone changed/built in 400cm3 Audi TT-S3 injector in the Mini or if i cant buy JCW what shall i use instead?
Thank you
Norbert
Old Feb 3, 2009 | 04:43 PM
Luys's Avatar
Luys
Can I ask why you cannot buy JCW injector?
Old Feb 4, 2009 | 04:38 PM
Ryephile's Avatar
Ryephile
The vast majority of OEM injectors are "high impedance".
The main concern for most non-MINI injectors are the overall height of the piece; the intercooler is very close and a taller-than-stock injector will result in an interference-fit with the intercooler [aka doesn't jive]. "Standard" height injectors are taller than the MINI's injectors [both stock and JCW]. Call up RMW and get some 440cc/min if you're pushing big power on the stock ECU. Any bigger and the stock ECU's LTFT can't adapt fully and you'll throw CEL's [not to mention not be able to idle!]
What are you doing to think you need to get all crazy with the fueling system? It's unlikely whatever you're doing already hasn't been done and figured out.
Cheers,
Ryan
Old Feb 4, 2009 | 06:40 PM
Mike@Mynes's Avatar
Mike@Mynes
Cheers,
Ryan
Ryan is correct, MINI uses the "high impedance" similar to those in Hondas... the connector type is EV1.
I have used the RC 750cc injectors (SH4-750) on my 06 MCS running E85 fuel and it ran fine with no check engine lights. Only hickup is between 1000 and 2000RPM b/c the injectors are hard to modulate at that range, but at over 2000RPM, the car runs and drives normal.
I'm getting some 550cc Bosch injectors with adapter connectors this week, will try that out and see if it's too long for the stock IC.
Of course, whoever tunes your car will need to scale the injectors accordingly to get your car running smoothly.
cheers.
mike
Old Feb 5, 2009 | 07:42 AM
Thumper460's Avatar
Thumper460
good... good... subscribing
Just me.......................
Thumper
Old Feb 5, 2009 | 08:28 AM
Mike@Mynes's Avatar
Mike@Mynes
the 550cc Bosch injectors that i mentioned are the same ones we used for Kalvin's car:
https://www.northamericanmotoring.co...91-octane.html
these injectors are extremely smooth and nice to calibrate... they do exactly what you tell them to do. It works great on Kal's car b/c we don't have to worry about the injectors being too long and hitting the Intercooler b/c he's running a front mount with the turbo-only setup.
Once i try them on my car, i will post some feedback on how they work on the R53 supercharged units.
cheers...
Old Feb 28, 2009 | 08:13 AM
jhiggs26's Avatar
jhiggs26
Are the stubby Bosch 380cc injectors fine to use for mild mods-with an eventual rolling tune-or should one stick to the OEM Siemens/JCW 380cc injectors? Looks like the Bosch go for $55-60 per injector.
Jeremy
Old Feb 28, 2009 | 10:04 AM
AZblackOUT's Avatar
AZblackOUT
Update, the 550cc Bosch injectors fit perfect under the stock IC and the AltaV2 IC... just ordered and installed mine
Old Mar 1, 2009 | 12:03 PM
D-MAN's Avatar
D-MAN
Found these on ebay...
Cheap considering what others sell them for
380cc
http://cgi.ebay.com/ebaymotors/Bosch...Q5fCarQ5fParts
and
450's and 550's
Old Mar 1, 2009 | 12:15 PM
jhiggs26's Avatar
jhiggs26
Hey D-Man those caught my eye recently too. I've asked if they're dual cone sprays or just single stream. Injector OAL could be an issue and I've asked about that as well.
For the extra dough it's probably better to go with the Siemens/JCW though. Less fussing with OEM parts and such.
There's quite a disparity in pricing for the Siemens/JCW from our NAM vendors($300-$600). I should have bought some last summer when the Canadian dollar was on par or better than the greenback!
Jeremy
Old Mar 2, 2009 | 10:35 AM
jhiggs26's Avatar
jhiggs26
Originally Posted by D-MAN
Ok I heard back about those Bosch 380cc injectors. They are straight stream with a 4 hole disc type nozzle.
Questions:
Anybody tried these injectors? Would they flow better than the stock 340cc injectors in upper rpm band with that staight stream or not? I'm just worried about atomization/puddling. Can we get different nozzles. I think Helix Minisports has 380cc Bosch's with OEM dual cone spray pattern. Maybe they can get different nozzles for these injectors.
Jeremy
Old Mar 2, 2009 | 02:20 PM
oxtox's Avatar
oxtox
got my jcw's for under $300 shipped http://cgi.ebay.com/ebaymotors/Mini-...Q5fAccessories
Old Mar 2, 2009 | 02:33 PM
jhiggs26's Avatar
jhiggs26
Thanks for the link Oxtox.
Are they in your MCS yet?
Jeremy
Old Mar 2, 2009 | 02:51 PM
oxtox's Avatar
oxtox
you're welcome.
no. the cam of many names is in but the injectors are waiting for the helix move/jan tunefest....which god only knows when it will occur (june?). i couldn't pass up on the deal because i knew i would be getting them eventually. so for now they sit next to all my detailing products.....waiting................
Old Mar 2, 2009 | 05:22 PM
jhiggs26's Avatar
jhiggs26
Oh that would be killing me Oxtox. Why not throw them in and have RMW/Jan remotely tune your MCS? I think he's almost got the remote flash tools ready for the market.
Jeremy
Old Mar 2, 2009 | 06:32 PM
oxtox's Avatar
oxtox
Jeremy
ha ha....trade in my "it'll happen someday soon" for an "almost there?"
and yep, it is killing me....i'm normally an immediate gratification kind of guy
Old Mar 2, 2009 | 08:45 PM
jhiggs26's Avatar
jhiggs26
I love that 1st line Oxtox. I really didn't throw you a bone did I.
Ok what about putting the 380's in and getting a JCW flash to hold you over until your rolling road tune.
Jeremy
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
Manny_cooper
Sep 3, 2015 05:48 AM
