Drivetrain OBD2 can reader
Old Feb 3, 2009 | 05:47 AM
spam052's Avatar
spam052
OBD2 can reader
im looking for a can bus reader that will work on our cars anyone know of a good one? i have a cel that won't go away after using the alta unichip. i tok the chip out and still i have that $%^*^ cel.
Old Feb 3, 2009 | 12:55 PM
chakraj's Avatar
chakraj
Mossmini has one, it says its for up to 06, but it does work on the R56 also
Items: 0 Subtotal: $ 0.00 All Parts & Accessories > Car Care,Tools & Shop Supplies > Tools
Mini-Specific Scan Tool
Having a scan tool is a great addition to your tool box, especially if you do your own maintenance work on your Mini. This tool is specific to the Mini, with all of the specific BMW codes and the ability to reset check engine and maintenance lights. A generic scan tool will not reset your lights or read certain BMW specific codes. For example, you've done an oil change yourself. If you don't have this scan tool, the lights on the dash need to be reset, which means making an appointment at the shop, and taking it in to the mechanic, and all that hassle just so the shop can plug in their tool and reset everything. Then you have to pay a bill for that service. You don't need to go through any of that hassle if you have your own scan tool! And if you've got a check engine light, you can scan to find the code for the malfunction, before you even call the shop for an appointment! You will have peace of mind knowing you're as knowledgeable about what's wrong with you car as the mechanic is.
Part #PriceDescriptionApplicationQty
RqdQty 103-225 $139.95 R5 Scan/Reset Tool02-06 All Hatchback
04-08 All Convertible 1
Old Feb 3, 2009 | 05:07 PM
Minidrivr's Avatar
Minidrivr
Seems like the most cost effective solution for a scan tool that can reset CELs would be a Scanguage II.
Old Feb 3, 2009 | 05:10 PM
scott48's Avatar
scott48
scangauge
Old Feb 4, 2009 | 05:06 PM
Noegel's Avatar
Noegel
This might sound silly, but where is the port for the OBD-II readers? I'm about to get one, since I'm about to order the ALTA downpipe, and I'm going to need to reset the CELs that will come with it.
Old Feb 4, 2009 | 06:01 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
The port is by your left knee.
Old Feb 4, 2009 | 07:24 PM
Noegel's Avatar
Noegel
Thank you, I'll check again!
thadscottmoore
Jun 4, 2021 07:19 AM
navybsn
Oct 5, 2018 04:42 PM
JLSM511
Feb 25, 2016 01:02 PM
Oct 19, 2015 08:07 PM
mimaal
Sep 4, 2015 09:09 AM
