Drivetrain R56 Wastegate open
Old Jan 10, 2009 | 11:15 AM
FRATER's Avatar
FRATER
R56 Wastegate open
Is the R56 wastegate suppose to be open a little?
Old Jan 10, 2009 | 01:30 PM
Ryephile's Avatar
Ryephile
Absolutely, and not whatsoever; "It depends". What's your question?
Old Jan 10, 2009 | 01:34 PM
FRATER's Avatar
FRATER
When my mechanic took off my downpipe he was looking at the wastegate and it was open, he said he has never seen a wastegate open like that but he said it might be different on the Mini. He said most Turbo wastegates are closed. Any idea?
Old Jan 10, 2009 | 01:38 PM
Ryephile's Avatar
Ryephile
Find a new mechanic that knows current BMW operation. He is traditionally correct, most off-the-shelf aftermarket turbochargers use default-closed wastegates with calibrated springs to open at a certain boost pressure, however this has limited control even with an EBC.
BMW chooses to operate their turbo engines with a default wastegate-open situation, and a vacuum pump is computer controlled and pulls the wastegate shut depending on operating conditions and driver input. It will only pull the wastegate shut when enough torque is requested the engine operates with boost.
I hope that helps,
Ryan
Old Jan 10, 2009 | 02:17 PM
FRATER's Avatar
FRATER
Thanks Ryan!!
Old Jan 14, 2009 | 11:37 AM
MrB's Avatar
MrB
Do i suppose to modify the wastegate?
just wondering because there are a lot of choices outthere, i.e. HKS & Greedy
Old Jan 14, 2009 | 02:20 PM
MotorMouth's Avatar
MotorMouth
only if you think HKS and Greedy know more about the MINI than BMW does..
in others words - don't do it.
Old Jan 14, 2009 | 02:26 PM
Ryephile's Avatar
Ryephile
What's your intention?
SheldonCooperS
Aug 25, 2015 11:57 AM
WestfaliaR
Aug 19, 2015 08:01 AM
Bennyboy
Aug 18, 2015 07:28 AM
speedbird_1
Aug 15, 2015 04:44 PM
