Drivetrain Clamping the MAP sensor
Old Feb 26, 2009 | 10:57 AM
  #26
Paul Webster's Avatar
Paul Webster
But you could do with a holiday Jay via England of course, welcome to NAM.
Old Feb 26, 2009 | 07:41 PM
  #27
1FSTMINI's Avatar
1FSTMINI
Originally Posted by jaytech
If I was in Greece I would tune it for you. The MINI main fuel map Y axis which is 16 elements in size and it is scaled to a max of 7000 RPM. You can increase these cells by changing the Y axis of the fuel map up to 8000 RPM and the ECU would use those changed cells and use it's table lookup interpolation subroutine to scale the fuel map to 8000RPM when it reads the scale from Flash and store it in IRAM (internal RAM). This function is not available through Dimsport.
Jason
where r u located?
Old Feb 27, 2009 | 01:30 PM
  #28
jaytech's Avatar
jaytech
Originally Posted by 1FSTMINI
where r u located?
Loacated in Arizona (MYNES) and California (ABF) contact Mike of Hubie for more information. We have gotten more into the MINI ECU code. Can even change your low and high speed fan ON/OFF temps to accomedate a colder thermostat. We also turn off closed loop operation within the code when tuning to scale larger injectors. This allows us to correctly scale in the injector without fighting with the ECU closed loop short term and long term trims after resetting the adaptations. When tuning is done, we turn the closed loop operation back on. It's always good the reset adaptations if long term trims are +/- 5 % before any flash is done.
Jason
Old Feb 27, 2009 | 02:31 PM
  #29
1FSTMINI's Avatar
1FSTMINI
im in NY so that only figures your nowhere near me
Old Feb 27, 2009 | 03:31 PM
  #30
jaytech's Avatar
jaytech
That's not a problem, that's why we have airplanes right? Also I am planning to tune some MINI's in NY coming up soon anyways. I'll keep you posted.
Jason
Old Apr 30, 2009 | 06:29 AM
  #31
thanosman's Avatar
thanosman
hi everybody
i finally installed the larger injectors (440) two months ago and i faced the problem successfully.
my Air to Fuel ratio is 11.4 - 11.6 at the highest revs. this is a good and safe number.
i run the mini at 7500rpm but after 7000 i face a significant power drop.
i run at 226 whp until 7000 and then i lose many of them...
i will try to retune it again very soon...thank you all for your contribution
Old Apr 30, 2009 | 09:01 AM
  #32
Longboard Mini's Avatar
Longboard Mini
Originally Posted by thanosman
hi everybody
Nice power thanosman. Very cool to see things worked out .
Longboard
Old Apr 30, 2009 | 11:21 AM
  #33
Mike@Mynes's Avatar
Mike@Mynes
hi everybody
Thanosman, sounds like you can benefit from an upgraded camshaft. MegaMini recently released their MM254243 camshaft with excellent test results. This camshaft provides smooth low-end torque and delivers high-end power all the way to 7800rpm (and it's not hard on the drive train). Details of this cam is located here:
http://mynesperformance.forumotion.c...ni-cam-t57.htm
cheers.
mike
Old Apr 30, 2009 | 12:49 PM
  #34
thanosman's Avatar
thanosman
@longboard thank you for your kind works...i hope very soon i will be able to provide higher numbers without changing my setup
@mike@mynes thank you for the info but i already have the rmw camshaft. i am very happy about his performance and i do not see a reason changing it
Old Apr 30, 2009 | 01:12 PM
  #35
Mike@Mynes's Avatar
Mike@Mynes
ah, got it. I didn't see the Cam listed in your mod so i wasn't sure if you had one or not... cheers...
Old Apr 30, 2009 | 01:33 PM
  #36
newbs49's Avatar
newbs49
thanosman
Old RMW cam or the new track cam?
Old Apr 30, 2009 | 01:36 PM
  #37
thanosman's Avatar
thanosman
the old classic street powerful camshaft
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Sep 10, 2015 10:52 AM
Richard Kellstrom
Sep 4, 2015 07:21 PM
