Drivetrain new grs front mount intercooler pictures
Old Oct 31, 2008 | 09:51 AM
  #51
MINIdriver85's Avatar
MINIdriver85
Originally Posted by PARTSMAN
If you pop the hood on you car and look straight down, you will see that with A/C condenser mounted in front of the radiator there is no room for the GRS FMIC. The condenser has to go in order to fit the FMIC...no condenser, no A/C.
What about relocating it? Maybe making a custom condenser to fit another location?
Old Oct 31, 2008 | 10:20 AM
  #52
Partsman's Avatar
Partsman
Legion_of_Doom
I'm not sure where you would mount it...all vehicle manufacturers put it in front of the radiator for airflow reasons.
I am also not sure on the minimum size requirement of the condenser to be able to give the optimum cooling for any given system. The MINI one is pretty decent size...and I would imagine a custom one, if not placed directly in the airflow path, would have to be bigger/thicker(?) to get the same cooling as the stock one in the stock location.
Old Nov 1, 2008 | 12:51 PM
  #53
soccerbummer1104's Avatar
soccerbummer1104
you know you could do a crazy mod, get rid of those "horns" for the final production, and some how pipe the AC condenser up to where the intercooler used to be. basically swap the places they were. AC would not work as well, but at least you would have some. ( maybe have design for the condenser similar to the straight through design on the m7 dfic) idk if it would work, but its an idea.
Old Nov 1, 2008 | 11:31 PM
  #54
silversmoke06's Avatar
silversmoke06
Jack walked and E46? No kidding.
Old Nov 1, 2008 | 11:54 PM
  #55
silversmoke06
The intercoolers neato though.
Old Nov 2, 2008 | 12:36 AM
  #56
MINIdriver85
That is what I was thinking too
Old Nov 2, 2008 | 05:09 PM
  #57
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Not quite following that your saying?
Old Nov 2, 2008 | 05:32 PM
  #58
ManikMini21's Avatar
ManikMini21
Being able to walk an e46 in Los Angeles would be great considering the amount of uptight bozos that drive them out here. They give the cool e46 drivers out here a bad name.
Old Nov 4, 2008 | 11:12 AM
  #59
call it spade's Avatar
call it spade
Say if I were to relocate the TMIC to a FMIC without removing the A/C would the FMIC block/restrict air to both the Radiator and A/C? If so, how much would it affect the engine?
Old Nov 4, 2008 | 04:10 PM
  #60
Intense's Avatar
Intense
252whp 200trq RMW style
I still haven't received one for testing yet
Old Nov 5, 2008 | 09:05 PM
  #61
not-so-rednwhitecooper
How about notching the top of the bumper and the impact bar, and using a single sided core with a pair of end tanks that will flow with the contour of the grille?
You could even use oval charge pipes if it was that tight against the hood or grille...
Unless I want to go for over 250 again, i'm just gonna look for an old Alta IC and run meth.
Old Nov 6, 2008 | 06:41 AM
  #62
Partsman's Avatar
Partsman
Legion_of_Doom
Cool to see you in here posting again, Rick. Welcome back.
Old Nov 6, 2008 | 12:12 PM
  #63
Thanks man, it feels good to be back!
Old Nov 6, 2008 | 12:26 PM
  #64
Paul Webster's Avatar
Paul Webster
http://www.minitorque.com/forum/f24/...96/index9.html
Post 88 for the latest update
Old Nov 6, 2008 | 02:48 PM
  #65
Intense's Avatar
Intense
I can't get your link to work Paul
Old Nov 6, 2008 | 02:49 PM
  #66
Damo's Avatar
Damo
MT seems to be down at the moment :(
Old Nov 7, 2008 | 12:19 AM
  #67
Jove's Avatar
Jove
The site is back up now
Old Nov 7, 2008 | 08:44 AM
  #68
MiniStupidfun's Avatar
MiniStupidfun
Where do i sign???
Old Nov 7, 2008 | 09:19 AM
  #69
Longboard Mini's Avatar
Longboard Mini
Smart guy . I think it can be done while still keeping the AC in place. The oval charge pipes are the key .
Longboard
Old Nov 7, 2008 | 01:06 PM
  #70
Longboard
Hrm, if I cant get a cheap Alta, maybe i'll pick up where I left off on my old FMIC project from my '03 S and finish it on the new car...
Old Nov 9, 2008 | 06:43 AM
  #71
Vernon29RW's Avatar
Vernon29RW
Here ya go: Alta A2A
The seller looks a little iffy with zero posts and no pictures but he's got an email address to contact with. Hope this helps...I'm always willing to help a little to witness progress in performance.
Steve
Old Nov 9, 2008 | 05:46 PM
  #72
BigShow's Avatar
BigShow
Air-con... meh! The beauty of living in the UK, haven't had air-con for some time as took it out to save weight for the track and strip. Car is still very much a daily driver though. Reason for going FMIC was the temps on track were just getting too high and so I was losing power.
On cruise the FMIC hovers between ambient and ambient +1C whereas the top mount was + 8C average. Not got it on track yet but will be re-mapping the car on Tuesday so will be publishing a full report on MiniTorque then with dyno graphs showing the car with top mount vs FMIC and plenty of pics.
Spec of the engine is:
- RMW Head
- RMW 440c Injectors
- 1320 Camshaft
- GRS Front Mount
- 1320 Custom Remap
- JCW CAI (flap removed)
- Alta V2 17% Pulley
- Janspeed Manifold (de-cat)
- Borla Exhaust
- NGK Spark Plugs
- RMW Oil Sump Baffle
Old Nov 11, 2008 | 10:27 AM
  #73
BigShow's Avatar
BigShow
Front Mount Testing Results can be found here:
http://www.minitorque.com/forum/f24/...290/#post25162
Old Nov 11, 2008 | 01:01 PM
  #74
MiniStupidfun
Veyr nice, so the real question is when can we order this!
Old Nov 11, 2008 | 01:03 PM
  #75
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by BigShow on MiniTorque
* By removing the air-con, the ECU keeps the engine fans running constantly whilst the engine is on. Bonus if you ask me
If you plug the pressure switch back in to the harness, the fan will function like normal and stage 1 will only come on when it's supposed to.
Right now the fan is running at stage 2(as if the A/C were on). This may save you from premature fan failure.
BTW, thanks for posting the TMIC vs FMIC chart.
