Drivetrain Crankshaft pulley
Old Oct 14, 2008 | 07:38 AM
mdbsat's Avatar
mdbsat
Crankshaft pulley
Hey guys. I am going to get an aftermarket crankshaft pulley so this thread doesn't need to be a debate on whether it is a bad idea or not but my question is whether or not to go with the 2% or Stock size. Just wanted to get some input as I will making this purchase shortly. Other than what is in my sig everything else is stock. Thanks guys!
Old Oct 14, 2008 | 09:32 AM
JIMINNI's Avatar
JIMINNI
Go with the 2%. I also have a 03 and was told it helps with the low end torque that our transmission lacks compared to the 05 and up . Have had no probs with mine
Old Oct 14, 2008 | 09:40 AM
mdbsat's Avatar
mdbsat
I guess my main concern is the extra heat that will be produced and having the stock header. I am def. leaning the 2% way though. Thanks for the reply
Old Oct 14, 2008 | 10:22 AM
Professor's Avatar
Professor
So the 2% is a larger or smaller pulley? I would like to see a larger than oem crank pulley. Would that not translate into spinning the SC faster?
Old Oct 14, 2008 | 02:58 PM
D-MAN's Avatar
D-MAN
I run a 16% + 2% and have had no problems!
Old Oct 14, 2008 | 05:15 PM
Darrinyuan's Avatar
Darrinyuan
I have 19% plus 0% and running fine too.
Old Oct 14, 2008 | 05:24 PM
Ryephile's Avatar
Ryephile
0% [with a 15% s/c pulley] is still the ticket. Anything "more" is just over-driving your accessories, not to mention creating hotter IAT's than power. You might be able to make a case for a larger crank pulley if you only drive around town, but if you track your car, it's not worth the heat.
Old Oct 14, 2008 | 06:26 PM
mdbsat's Avatar
mdbsat
Ah, Ryephile. I was going to send you a PM. A trusted member told me to ask YOU about this. I only use my car as a daily driver and I dont ever plan tracking my car. I mean of course I drive on the highway as well. Would you still say go with the 0%?
Old Oct 14, 2008 | 08:40 PM
Ryephile's Avatar
Ryephile
Personally I run a 15% s/c with a 0% crank pulley. It's great around town and will not cause any problems on the track. Considering your relatively warm location, I would recommend the same setup for you. If you want a bit more boost at lower RPM, I'd recommend a 17% s/c pulley versus a larger crank pulley.
I hope that helps, and good luck!
Ryan
Old Oct 14, 2008 | 08:43 PM
mdbsat's Avatar
mdbsat
Ryan
It sure does. Thanks Ryan. Ill get the 0% crank pulley. For some reason I forgot I live in a place with 95+ degree heat for months on end
Thanks to all who posted.
Old Oct 14, 2008 | 09:20 PM
mini_racer's Avatar
mini_racer
Changing the Crank Pulley
Understand that you are changing the crank pulley, so no debate, fine. However, since you have decided on 0% size change, you may want to consider a purchase of an '05 or '06 model OEM pulley. It saves significant weight over the '03 version, but definitely not as light as aftermarket. Of course, it will also have the dampner function, being OEM. Some one these forums believe that is absolutely critical, definitely not all though. As you know, this is hot item for debate.
You may be able to find a slightly pre-owned OEM '05 or '06 crank pulley for much less than new aftermarket, if you are looking for a less expensive option.
BTW, a very easy swap through the passenger wheel opening.
Good Luck, and if you go with a 0% this will NOT affect your upcoming tune in anyway. Something else to consider. From a perf standpoint, this change would be like removing weight from the car.
Old Oct 14, 2008 | 09:32 PM
Darrinyuan's Avatar
Darrinyuan
I have 19% plus o because I have giac chip,alta v2 intercooler,jcw 380cc injector,obx header,borla exhaust and dinan tb,schrick cam,it pully hard after first gear with no problem at all.Before I'm running 19 plus 2,when I race hard I broken my tension,so I change to 19 plus o now.I not recommand people choose 19 plus 2.
Old Oct 15, 2008 | 02:03 AM
MINI_chili's Avatar
MINI_chili
I read somewhere that most aftermarket crank pulleys are so much lighter than stock that it's about the same as taking 100 lbs. off your car
Old Oct 15, 2008 | 03:16 AM
norm03s's Avatar
norm03s
Thats a bit overstated don't ya think?
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
