Drivetrain Removing Alta V.1 pulley
Old Aug 30, 2008 | 10:11 AM
Longboard110's Avatar
Longboard110
I did a search and didnt come up with anything. I am going to be removing my V.1 Alta 15% pulley and was wondering if I will need a puller or do they come off when you unbolt them. Im assuming they come off without a puller, but just wanted a second opinion before I dig in.
Old Aug 31, 2008 | 07:35 AM
ih8cornnuts's Avatar
ih8cornnuts
It comes off without the puller. Just loosen those socket cap crews and it should come right off. Then slide the collar off the supercharger. Some wd-40 might help if things are tight but try it without first.
Old Aug 31, 2008 | 09:25 AM
k-huevo's Avatar
k-huevo
Remove the fastening/clamping bolts first, there are two threaded holes on the pulley face, using bolts longer than those used for clamping (same thread pitch and diameter), screw in to separate. No need to go as far as the photo below, it is only a general illustration; I’m using Campy quick release skewers here.
Teh
Aug 22, 2022 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
