Drivetrain Oil cooler... why isn't anyone using one?
Ten minutes into numerous thirty minute track sessions my 05 JCW/S chrono pack oil temp read steady @ 275 F. Never rising higher, and returning to normal @ 225F on the cool down lap. Yes, that's a wee hot for my tastes. I'm ready for a cooler
check out this link
Actually, this topic has been addressed in other related threads. Check out this particular thread from our local BMW CCA website for some data and an example of a track proven oil cooler installation for MINI: http://www.bmwpugetsound.com/vbb/showthread.php?t=31542
If you have questions, I'd be happy to try and answer them.
Hope this helps,
John Petrich in Seattle
Hope this helps,
Oil volume about the same
Tony,
Hope that you are recovering from the heat and Nana's death.
The oil volume in the cooler is a little less than 1/2 quart extra but the oil in the cooler doesn't drain with an oil change. So, I continue to fill with about 4 3/4 or so quarts after each oil change.
In truth, I cannot get the oil temperature to exceed 220 degrees F even on an 80 degree F track day. Sure seems to function as an effective oil cooler.
Hope this helps,
Hope this helps,
I was wondering if that was the case... Thank you John.
Life is finally starting to return to a sense of normalcy, but not quite yet. Visiting a high school buddy in your neck-of-the-woods (Seattle) in three weeks, and then the wife and I are catching a ferry boat to Victoria. We heard it is beautiful.... can't wait!
Glad that you have an effecitve oil cooler for your track days! I have a feeling that M7 might have something interesting some day soon, but with a spin to it
. Thanks again for sharing!
Originally Posted by MSFITOY
With all the "hard" driving members here, I've never heard the mention of anyone using an oil cooler. I'm seriously considering the Moss system as theirs also converts the filter to the more common spin-on type. Anyone else have thoughts on this?
With Dr. O, I did some testing on the GRS and stock IC's, and hood scoop combos. I actually just removed my GRS, and the DFIC is going on in the next hour or so... I'll have some data and impressions...
Yeah I don't think they are made for R56. And even for R53 there was only afew kit made: Moss (Cobalt), MINI Mania, and MINI Madness that sold them as a kit. Some others but you had to gather the bits like: oil cooler, hoses, clamps, and stuff individually.
I just installed a great oil cooler kit made by Sneed's Speed Shop in Pfafftown, NC. It's complete with adapter plate, hoses, fittings, large cooler and instructions.
http://www.sneedspeedshop.com/MINICooperParts.html
I have put my Oil Cooler on and I have an oil temp gauge and I was amazed. After a bit of spirited driving, not too much as it isn't tuned properly yet, My oil temp gauge was just sitting at 80 degrees Celsius. Yeah I live in Australia. It didn't budge from it. This is around 176 degrees Fahrenheit!!!! This isn't a proper test but a very good indication that they work and work well. I also noticed that the temp gauge of the actual car was sitting lower than normal so as I have taken the heat exchanger away from the system and have the oil cooling via a proper cooler the Coolant isn't getting hot from trying to cool the engine oil down.
To top it off, I thought I would just do the old touch test. Damn, I could hardly hold the inlet side but I could hold the outlet. So I will be wrapping the outlet side soon with a heat shield so no heat transfers. I wanted mine to look stock so all I did was use the Mini Madness Adpator plate so I could put my oil Temp and Pressure gauge in, Ran 2 hoses up to the under side of the window cowl, installed a Mocal Thermostat, and then ran the hoses to a modified Auto Transmission Oil Cooler. The bolt straight up if you don't have an Auto. I just got the Inlet and Outlet pipes cut off and welded some larger diameter ones on. I will post pics soon.
I've said it before and I'll say it again. Unless you track the car and notice oil temps north of 240, an oil cooler would probably do more harm than good (especially if it doesn't have a thermostat). 225 F is the sweet spot for most oils. Above that, heat starts taking its toll and below that, your loosing power due to the fluid being thicker. 176 F is pretty darn cool for oil. What were your temps before installing the cooler? I drive in Florida heat and have never seen above 230 on the highway (215 after I switched to Redline oil). Oil temp is highly related to rpm. Even in 100 degree heat, it'll start dropping at a red light.
That's why I installed the cooler. I'm a DE instructor and run about 10-12 events a year. On-track oil temp. has been consistently running 260-265F at the filter which means it's way hotter in the sump. I just installed the cooler and took it for a test ride to check for leaks and normal temp. It stabilized at 200-210F w/o incident in a normal timeframe. In the Winter, I'll just stick a piece of cardboard in front of the cooler if it doesn't warm up...but I bet it will.
they're big , like 4 x4 x 1 but will fit on passenger crush tube .
oil is oil so if you know the line size they'll fix you up . you just gotta know which is delivery and which is return . disable the ign. and fuel . on a 53 it's a relay , and have someone crank it for you and the one that pisses oil is delivery . just remember to use push on hose if using push on fittings . try "think automotive" in u.k. ot/2 is all for a part #
