Drivetrain VIP engine stabilizer $99?
Let's hope gen. 2 is better as I trust it would be.
Ok, slightly off thread, but close enough I hope to not incur anyone's wrath.
I tried one of the Madness lower engine mount inserts, and it just made vibrations and noise, especially at idle. Is this typical.
So, back on the VIP upper, seems like it is quiet and functional.
Are lower inserts of little noisey value, and you should just get an upper add-a-damper and not worry about the lower??
lower mounts add NVH...just a fact of life. They do however make more difference than any upper mount could ever do on it's own - it's a function of pivot points. With lower inserts and the VIP on mine, there was very little engine movement on full power pulls on a dyno (240whp). I've got a nice mp4 video...if I can somehow convert it and share here, I will.
Thanks PGT,
I am not a big fan of NVH. Maybe I just need to get the VIP upper and then be done with it.
Since I have a dyno run coming up, I might put the lower insert back in for that adventure, but for daily driving the excessive NVH is crazy.
Just doing the upper for daily driving might be a good compromise.
ok....lets see if this works (it's a quicktime uploaded to youtube...might still be processing):
powerflex gearbox bushings, Ireland engine bushings and VIP damper. I saw another MINI that day with the TSW and the LOTF installed and that motor was bouncing ALL over the place in comparison.
ok, edited the link....it works now. Seems my attempted upload a few months back DID work and all subsequent ones failed because they were duplicate efforts (iPhone app to record video and upload straight to youtube).
Had the LOTF engine damper and it completely failed at a Phil Wicks, sense been replaced with the VIP and it's simple dogbone design with the movement being dampened in the rubber bushings is very OEM. I give it a big
and another
for good measure.
yea...you n doc said some things. wish i bought it back then. i still feel the motor rocking on hard on/off accel/deccel
sooo...i was under the hood yesterday and i found the dog bone bushing on the large side coming out of place. i was able to push it back in but its just going to come back out.
EDIT: just talked to the guys at VIP. I guess im the FIRST one to have this happen to. YAY. They will be sending me out a new dog bone.
EXCELLENT customer service.
dude....that rocks that they took care of you.
Did you have it in the right way? It's easy to get it backwards....one side is larger than the other and I think if you get it reversed, teh bushing wants to give at an angle other than what's needed.
i went by all the pix i seen....big side upfront. they said there is a 5* angle which is normal.
silence2-38554
Nov 12, 2015 09:39 AM
Powershift
Aug 16, 2015 05:14 PM
