Drivetrain just a thought on heat control
so lately i have been trying to controll the heat in my engin bay, especially as it pretains to my intercooler. as heat rises, it seems that a good deal of that heat comes through the top of the motor where the injectors and fuel rail sit, under the intercooler, and heat it up pretty quickly, even with an alta diverter on top. i was wondering if a division between intercooler and motor would be beneficial, somthing like a header blanket directly under the intercooler.my only concers are that keeping the heat on the fuel rail will cause problems and that the material will restrict airflow. any oppinions, comments or suggestions would be great. thanks
I addressed the problem of engine heat reducing IC efficiency in this thread:
https://www.northamericanmotoring.co...ad.php?t=80549
you could also use this product with altas TMIC, basically the same thing
but yeah i was thinking about having another air intake to blow off the underside of the intercooler to vent off the hot air? maybe with a simple bolt on part directing just a little bit of the air flow through the grill from the radiator up to the underside of the intercooler
maybe???? just a thought
vendors should pick up on that idea and patent it before i do, by the way haha
maybe???? just a thoughtvendors should pick up on that idea and patent it before i do, by the way haha
ok, so wehile on the subject of heat controll, would changing the coolent resevior tank to an aluminum tank help to lower coolant temperature? thanks
My little dose of LITHIUM
Is the coolant temperature a problem? No need to fix it if it ain't broke. Read all the posts about the 180F thermostat to get an idea of creating problems with a solution to a non-problem. I sense that most people with the low temp thermostats dont have them anymore.
A big solution would be to exhaust all the under-bonnet hot air in a more efficient manner.
maybe???? just a thoughthttps://www.northamericanmotoring.co...d.php?t=101043
it never ceases to amaze me, everytime i think im thinking "out of the box" some other mini owner has already beat me to it
! haha well you know what they say, "great minds think alike"
Closer to more recent threads: You may think about the heat device to cover the area only under the IC. Worry about the temperatures of the IC with a water meth system? You can also wrap the fuel rail to protect it from heat.
It has been reported on many threads that there is a extreme limitation of cool air coming in from the front of the Mini to help remove the heat. Try something new?
The "little scoop" never came into being commercially.
I believe it was a benefit, or as PGT said - it didn't hurt.
https://www.northamericanmotoring.co...t=little+scoop
i have decided to steal a little from everyone. im going to cut the center out of that piece of plastic blocking the IM but leave the shell, IE the wether stripping across the top and the extra duct for the airbox. the new hole should allow more air in wit the help of a duct. did you see any differance with that plate infront of your radiator from M7? thanks
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
Powershift
Aug 16, 2015 05:14 PM
