Drivetrain how much hp can oem clutch take
Old Jul 24, 2008 | 12:30 AM
blue al's Avatar
blue al
how much hp can a oem clutch handle
mines at 30k and on its way, hopfull warrenty job
but am i repacing rubbish with more rubbish ?
will the flywheel still be good?
do i need an upgrade ? running 270 bhp
[not at the wheels ]
Old Jul 24, 2008 | 06:49 AM
jtack's Avatar
jtack
how are you getting it fixed under warranty? Usually wear items like a clutch isnt fixed under warranty unless there was a defect? I could be wrong though. 270 BHP would be right around 240 to the wheels...it might hold with that much hp...but with that much hp to the wheels your torque has got to be at least 190 and thats where you might have problems.
Old Jul 24, 2008 | 06:54 AM
El_Griton's Avatar
El_Griton
I pulled 200 ft lbs on the stock clutch with 55k on it.
Old Jul 24, 2008 | 09:25 AM
ThumperMCS's Avatar
ThumperMCS
When the replace a clutch they replace the flywheel, throwout bearing and pressure plate as well. I had mine replaced under warranty, it all depends on if your dealer is good or not though.
Also, I don't know the answer to your HP question, but I do know that it's torque which kills a clutch, not hp.
Old Jul 24, 2008 | 10:06 AM
//MZero's Avatar
//MZero
I think that around 200ft. lbs is about the max. Of course it all depends on how you drive it and what you are using the car for. El Griton apparently was fine with 200ft lbs, and by the looks of his sig he was having fun too :D
I've talked to Jan on this specific issue, and he also says it is around 200ft lbs. when you start to have some slippage issues. This is NOT saying you will burn up your stock clutch if you have 200ft lbs but that 200ft. lbs and above you should not expect a long living clutch.
Old Jul 24, 2008 | 10:30 AM
El_Griton's Avatar
El_Griton
Originally Posted by AeroCooper
...El Griton apparently was fine with 200ft lbs, and by the looks of his sig he was having fun too :D ...
I live by the age old motto, "Drive it like you stole it."
Old Jul 24, 2008 | 05:26 PM
kalbone's Avatar
kalbone
i tried that...and i broke it...
Old Jul 24, 2008 | 09:55 PM
blue al's Avatar
blue al
think i am firmly in the 200lbs club
for a "wear items like a clutch" will be informing my dealer that i have driven over 750,000 miles and never lost a clutch, mostly fords and toyotas,
my other drive is at 152 k at the moment on original clutch...
Old Jul 24, 2008 | 10:05 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
If you are really picky, the stock clutch is no good for even a stock MCS. It slips a ton when you really get on it. Mine used to a lot, then didn' slip with my old spec clutch and my mods. Now with the stock clutch again, and my mods still, it slips even more under high load. I hope it can last untill I can afford to replace it with a clutchmaster FX400 or FX500 and a light flywheel. It's been 5,000 agonizing miles with the OEM clutch and I'm tired of it.
Old Jul 25, 2008 | 05:41 PM
SteveS's Avatar
SteveS
jI think it depends how you drive. I am at 56000 mi. Dealer replaced flywheel under warranty at 26000 mi and I paid the $300 for clutch replacement at that time. Since then I've added a little power with Jan's assistance (240hp/190 ft lb.). My clutch does not slip, near as I can tell, even at Streets of Willow. But, I don't drop the hammer and shift relatively slowly. I always try to shift smoothly so clutch is not slipping much at all.
Your mileage may vary.
Old Jul 26, 2008 | 08:43 AM
Ryephile's Avatar
Ryephile
Of the two MCS's that I've needed to change the clutch on, my '02 was slipping during in-gear acceleration with only 162wLbFt @ 45k miles and my '04 was slipping with 170wLbFt @ 50k miles. This isn't just shifting aggressively but already being in-gear and then stepping on it and having the clutch slipping.
Old Jul 26, 2008 | 03:43 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Im at 210 tq with a luk clutch and about 15,000 hard miles and its doing ok!
Old Jul 26, 2008 | 04:26 PM
jhiggs26's Avatar
jhiggs26
What type of LUK pressure plate are you running Littlehandegan?
Jeremy
Old Jul 26, 2008 | 05:11 PM
littlehandegan
Jeremy
I beleive its the closest to stock, it was only around $126.
Jack
Old Jul 27, 2008 | 01:17 AM
blue al's Avatar
blue al
same as.... put my foot to the floor and all my ponies are pulling on a bungeee
this is only v.recent, did 5 trips up the strip a few weeks ago, do you think its connected?
Old Jul 27, 2008 | 03:20 AM
AZblackOUT's Avatar
AZblackOUT
I just replaced my stock clutch for an FX300 at 98,500. I drive hard, I shift hard and I love double clutching...I most likely still had atleast until 100k on my stock clutch plate
Oh, and I tow. 1000 lbs about 3000 mi (Quad and trailer)
Oh and this weekend I towed another MINI off the streets roughly 15 mi. Will never do this again, but I said 'what the hell, im replacing the clutch tomorrow so mine as well go out with a bang and help a buddy out at the same time...' your welcome UKSUV (second time grenading his tranny )
So respect is given to my stock clutch...it now hangs on the wall in the garage. dead center, as a momento for all it has done for me...or lettin me get away with
Old Jul 27, 2008 | 07:41 AM
jhiggs26's Avatar
jhiggs26
Wow nice to hear your MINI did tow duty with the stock clutch!
It's sad to hear about UKSUV's probs. Was this his new to him 6 speed going South on him???
Jeremy
Old Jul 27, 2009 | 06:46 AM
blue al's Avatar
blue al
well a year on and my replacement oem clutch is dying....
managed 15k on replacement
time to go aftermarket
is anyone sticking with the oem flywheel when swaping clutches?
or is it time to change the lot....
Old Jul 27, 2009 | 08:12 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'd highly recommend buying a new flywheel, since the stock one cannot be resurfaced. If you go to an aftermarket flywheel, be sure to get a sprung clutch.
Old Jul 27, 2009 | 08:29 AM
rjtrout2000's Avatar
rjtrout2000
I would look @ the clutch upgrade.
madmax88
Aug 21, 2017 07:07 PM
Branto
Aug 11, 2017 05:32 PM
blackie
Oct 2, 2015 07:41 PM
Camaro108
Aug 25, 2015 02:44 PM
FLYM1N1
Aug 16, 2015 01:15 PM
