Drivetrain Forge BBK for R56
Old Jul 14, 2008 | 10:04 AM
futureal33's Avatar
futureal33
Forge BBK for R56
Anyone got these?
Old Jul 14, 2008 | 10:09 AM
minipete07's Avatar
minipete07
Where did you find those?
Old Jul 14, 2008 | 10:15 AM
futureal33's Avatar
futureal33
http://cgi.ebay.co.uk/Forge-BMW-R56-...3286.m20.l1116
Old Jul 14, 2008 | 11:13 AM
benfica09's Avatar
benfica09
i'd be weary....i dont even see it on Forge's website yet.
I'd call Forge Motorsports to make sure its legit and they actually produce a bbk for the r56.
Old Jul 14, 2008 | 12:54 PM
japper's Avatar
japper
They're legit. They've been out a few months and are available in a group buy on MINI2 for around £950. They're 330mm discs and 6 piston calipers IIRC
Old Jul 14, 2008 | 01:42 PM
futureal33's Avatar
futureal33
any good???
Old Jul 14, 2008 | 01:51 PM
Mozza's Avatar
Mozza
Isn't $2K a bit steep?
Old Jul 14, 2008 | 02:17 PM
japper's Avatar
japper
Originally Posted by futureal33
any good???
No idea.
Old Jul 14, 2008 | 02:18 PM
japper's Avatar
japper
Not sure i've seen any BBK kit toting 2 piece 330mm discs c/w 6 piston calipers for anywhere near this price
Old Jul 14, 2008 | 03:53 PM
minipete07's Avatar
minipete07
think you can get a set of Wilwoods or Stoptechs for less
Old Jul 14, 2008 | 04:49 PM
Doc Cooper's Avatar
Doc Cooper
I think biggest BBK that you can fit is 14.1 in the front?? Very big for this small of a car... lol What's the best weight/performance ratio size?
Old Sep 14, 2008 | 04:33 PM
Longboard Mini's Avatar
Longboard Mini
They look like these D2 Mini BBK. I have a feeling they both use the same vendor out of Asia.
Longboard
Old Sep 14, 2008 | 07:27 PM
ghosthound's Avatar
ghosthound
6 piston calipers from forge probably arent as good as a 4 piston caliper from stoptech. Forge makes all kinds of goodies whereas stoptech only makes brakes.
Old Sep 14, 2008 | 07:33 PM
PGT's Avatar
PGT
same but branded Tarox 6piston sold by BMP Design:
Old Sep 15, 2008 | 06:26 AM
ichy600's Avatar
ichy600
I have this kit and It works great...the kit is not like the tarox...also the discs are differnt..
Old Sep 15, 2008 | 07:03 AM
PGT's Avatar
PGT
how are they different? look the same in the pics
Old Sep 15, 2008 | 07:06 AM
ichy600's Avatar
ichy600
look at the ventilation inside, and also at the thickness..and look well the caliper
Old Sep 15, 2008 | 07:21 AM
PGT's Avatar
PGT
ok. different apps then...same manufacturer....calipers look identical except for bridge thickness. they also make a 4piston and a 12piston one.
Old Sep 15, 2008 | 07:23 AM
PGT's Avatar
PGT
also...pic I posted was probably a generic one, not the MINI specific app so rotor thickness can't be judged on that alone.
Old Sep 16, 2008 | 06:29 PM
Longboard Mini
Actually the Tar-ox are their own. The rotors do look similar though.
But here is another one from the same manufacturer.
Forge
D2
K-Sport
Oops, these arn't like those .
Old Sep 17, 2008 | 12:50 AM
ichy600's Avatar
ichy600
yes the discs are the same, but the calipers in the photos are different...they are similar but the Ksport and the D2 are 8 pot calipers...the Forge have 6 pot...if you look at the 6 pot calipers by Ksport and D2 you can see that they have only 1 peg that keep the pad...the forge 6pot have 2 peg...
Old Sep 17, 2008 | 11:24 AM
clnconcpts's Avatar
clnconcpts
Wouldnt drilled rotors be better then slotted one's?I know I prefer the looks of the drilled ones
Old Sep 17, 2008 | 11:42 AM
BDBMCS's Avatar
BDBMCS
The "drilled" rotors will tend to crack (at the holes). Especilly if you track the car or if you are very hard on your brakes. The drilled holes will generate high stress points and the extra heat makes things worse. The slotted are less prone to cracking. Look at the rotors on race cars. No drilled holes or slots. Porshe casts their holes into the rotors. This is for the metal rotors. Not sure about the carbon rotors on high dollar cars.
rtk90
Aug 29, 2019 09:08 AM
Bennyboy
Dec 1, 2016 11:09 AM
newowner
Sep 15, 2015 07:18 AM
Sep 4, 2015 01:32 PM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
